PS
>I assumed that you're cutting plastic only. If you're cutting already-laminated sheets, use the finest blade you have but note that plastic will dull regular steel blades pretty quick, so carbide is called for. Also suggest you "tape" the cutline to help reduce chipping of the edges. Melamine's a bit softer that mica, but it still chips.
If you want to get obcessive about it, run you cut up to, but not through, the plactic layer from underneath, then score the top surface over the kerf and carefully snap the line. Lastly, trim the plasic back flush with a router and guided bit.
mm
