OT Need help making masks from plaster moulds
Hamish
>Not a woodworking question but an artistic one.
In preparation for a coming fiesta, I have been asked to make a dozen African masks. So I made two plaster moulds and then sealed them with a celulose wall sealer which gave them a smooth waterproof finish. From these I intend to make a run of masks out of newspaper pieces stuck down with watered down pva glue. I tried making the first one and on drying, I found that I could not remove it from the mould, it had stuck. So by forcing it out and destroying it at the same time, I found that it also lifted off the sealing leaving the bear plaster again.
My question is how should I proceed now? Should I smear the inside of the mould with vaseline before continuing in the same way as before (I'm not sure if by putting on the glue with a paint brush that it will wash away the vaseline or not), or do you think if I apply the glue directly onto the plaster that on hardening the mask will come away from the mould? Any suggestion will be welcome.
Thanks Hamish.
