Demagnetizing chisels?
Paul Woolson
>I've been haveing my chisels hanging on a magnet rack. Normally not a big deal because I seldom cut metal with them. ;^) But when I sharpen them, the metal shavings gather together and make a steel wool type concoction that really gets in the way.
I've made a new wooden rack and am wondering if there is an easy way to demagnetize them. Thanks in advance, Paul
Re: Demagnetizing chisels?
Larry in NW Ohio
>Paul You can but a magnetizer-demagnetizer from various places. I got mine from harbor fright. But being from the oppisite side of the world, it works backwords of course. Larry in Ohio
Smack down
Tom Dunlap in Atlanta
>The poles on the iron particles have all aligned in N-S orientation. One way to scramble them again is to lay the chisel, or screwdriver...since screwdrivers always end up being used as chisels sometime, right?!... across a flat surface. Take a hammer and tap on the chisel blade until the magnatizing is gone.
This can be used to magnatize screwdrivers too when you need to start a screw and you don't have a magnetic screwdriver. I've tapped on the end of the screwdriver or dropped it onto my vise/anvil and let the blade bounce a few times until the poles are aligned.
What's going to happen to all of the magnetized tools if/when the earth's magnet poles flip flop? :)
Tom
Mike in VA
>If you have a soldering gun, the style with the wire loop for a heating element, you can demagnetize you chisels by passing the end of the chisel through the opening in the loop. Just don't touch the metal parts of the heating element. There is an AC magnetic field inside the loop that randomizes the magnetic domains in the steel and removes the magnetism.
Ah, That Explains It!
>Good Morning Tom,
My father used to hold me upside down by the feet and tap my head on his anvil. He wanted me to have a magnetic personality. :<)
George
Know any machine shops?
Lee Schierer, McKean, PA
>Most machine shops have demagnetizer plates. You can lay your chisels on them and they will be demagnetized.
Or, (this doesn't work 100%) you can get a strong magnet and rub it along the chisels so the repelling pole is against the steel a few times and eliminate the magnetic field.
Lee
Lee Gordon
Lee Gordon
>If you have a big loudspeaker (preferrably a big ole woofer), you can try passing your chisel over the heavy magnet on the back of it.
del schisler
>sure If you have a weller solder gun Just hold the swith on and run the chisels between where the tip is screwed to the gun and tip Or between the tip and the gun part just thank of the copper tip as a circle it set's up a electro magnet And will dematize anything you put in their Or buy a demagnatizer
They will all point South :-)
Bob Fawcett
