Glass cutting, for the first time.
Dale Lenz
Dale Lenz
>I'm going into unknown territory, for me, glass cutting. It will be cutting single strength plate glass. I have a cutter(s) somewhere in the shop. My concern is sanding the edges. Can I take some 400 grit, W-D S.paper using a sanding block to "grind" off the sharp edges of the glass? I will be wearing leather gloves. Or should I purchase a "fine" sanding belt for my loud belt sander, mount the sander to the bench and work the glass?
Re: Glass cutting, for the first time.
why?
Tom Sontag - St. Louis
>The cutter scores the glass and you simply pop the two pieces apart (on a table edge or similar). Done correctly, you should have a very clean straight line with corners no more or less sharp than the other edges of your glass. I am not sure why you'd want to round over the edges since your pane will likely fit inside trim and not expose any edge. It is not normally done. I suppose fine grit silcon carbide paper would do what you ask though.
Just be sure to start with clean glass and score it in one pass. Bring the score just over the edge of your table find place a piece of wood on top of the keeper side (if you want) and push down on the scrap. It is a tad exciting, but with experience you'd do it with only glasses and no gloves.
Dale Lenz
Re: I like rounding over, : ' >
Dale Lenz
>Seriously, in my case, no pund intented, it's best.
Tom Stockton
>I wouldn't do it with power tools if an edge caught a flung the piece around you could really cut yourself bad. If you need the edge ground have a shop do it much safer. But as Tom said there is no need to do just for a window or something held in with stops or putty.
Tom
Again, why?
>To echo Tom's question: why?
You like rounding over. I do too, on wood. Not sure what that has to do with glass though.
Happy Woodworking!
Bill Hammond, Oregon Coast
>First time out do it by hand. it's rather exciting when the glass shatters and the bent or disk tosses it about.
bill
Clearly, Glass Can Be A Real Pane
>Dale get wet or dry sandpaper and go at it by hand. I use a sanding block. start about 220 if you want but 400 works well. I go up to 600 grit. It only takes a couple of minutes. If you want a perfect edge with no defects it will take quite a bit longer but if you just need a smooth edge that you won't cut yourself on once over with the 400 grit should do.
Re: Clean and lube your cutter....
Jamie Donaldson
>.. wheel with kerosene-if it has nicks toss it out and buy a shape one. Rounding unexposed edges is wasted effort, and 220 grit is fine enough for easing exposed edges-400 grit takes forever!!
Glass cutting lesson in Shop shots: *LINK*
Grant Smith
>Here's a leson in glass cutting I documented after my sister schooled me on the subject.
Let me expound on smoothing the edge of the glass after cutting, which is common if the glass will be used for shelves or if the edges will otherwise be seen.
Once the glass is cut to size, don your gloves and find some polished concrete floor. Slide the glass (lengthwise) on the floor while you alter the lean of the glass on each stroke. Never try to slide the glass accross, as this can break it... only lengthwise. you can also use a fine sharpening stone to fine tune your edges and round over the edges as needed, but I find the concrete floor is faster, tends to automatically straighten a less than perfect cut, and it is usually very handy.
Since my lesson, I have been cutting glass frequently for picture frames. Great capability to have around the shop.
Regards,
Grant in Iowa
Glass cutting in Shop Shots
Re: because...
Grant Smith
>Not all glass will be installed in a pane.
Many uses for glass with visible edges:
-Display case shelves (though single strength glass would not likely be strong enough, unless the case is small)
-side table protective tops..keeps the family idiots from ruining your nice wooden table. Tempered glass might be a better choice, however, especially if kids are around
-various crafts where the edge of the glass will be visible. My sister makes earrings and jewelry from fused art (stained) glass, and must round over the edges to prevent them from being sharp. And yes, she tempers the glass in her kiln afterward.
FWIW,
Grant in Iowa
Larry in NW Ohio
>Dale Don`t bother looking for your cutter, I`ve got it over here. I think it has it`s eye on my special pliers I use to break glass. Larry
And it's not all it's cracked up to be!
Joanne Adler in Pt. Pleasant, PA
And You Are Just The Lady To See It Through
Joann, Are Your Eyes Glazed Over?
Oh George, you crack me up!
Even if you are "sill"y.
Dale Lenz
Dale Lenz
>Thanks to all that offered their input.
I'm probably one of the worst to assume the poster is going to do something that is not said and offer advice on my assumption. In my case the user will occasionally clean the glass from the inside and there is no trim to cover the glass edge. I'd hate for the user to get cut on my account for not making the glass edge safe.
My glass shop told me today they sand their glass edge with 150 grit paper.
You guys' comments are windows to your souls...
Jason Roehl in Mulberry, IN
Re: rounding over
>We use a lot of 1/4" thick glass shelves and we normally get the shelves "pencil edged" from our supplier. I watched him do this once using a very specialized machine. It had grinding wheels and the glass was lubricated using a sprayer, possibly just using water but I think it was some sort of oil made for glass grinding. I think you could ease the edges of the glass slightly using silicone carbide paper but glass is very hard and does not sand easily at all. I have a flat piece of 1/2" glass that I tried easing the edges and got it good enough that I don't cut my hand when I use the glass but found it difficult to remove material.
How about...
Dan Donaldson
>How about using one of those small diamond paddles you can buy for sharpening. The diamond should cut the glass just fine.
Dale Lenz
Re: Now that's a neat thought....
Dale Lenz
>don't have a pocket size diamond stone but might try with my bench model. The glass does not need to be rounded-over just friendly to touch. The pencil edge would be fine, as Moses talked about.
Thanks a million, great ideas. Dale
What part of the Oregon Coast?.
Gary Camp - Bend, Oregon
>Dan beat me to it. I have used my diamond hones to slightly round over the edges of glass to make it more user friendly. Quick, easy and I did it dry. Sand paper works too, but I managed to get it wrapped around the edge and scratch the surface, Not good, so if you do, use a sanding block. I have also done it on my belt sander with the sander mounted with the belt up. The diamond hones were the best.
Dale Lenz
Dale Lenz
>I purchase a new DMT stone about two years ago off of Ebay for about 1/3 the price of new. The stone is not flat, no free lunch, : ' >. Your's and Dan's idea sounds like a good use for the 20 dollars stone.
Thanks again,
Dale
