Digital Readout for table saw fence
Paul Woolson
>I was at my local Woodcraft today and saw a really cool device that mounts to your fence and the rail it slides on. Then gives you an accurate digital readout. I was looking it over pretty well when the gent behind the counter (who knows me pretty well) stated "you still have to check the fence with a tape measure when it's set". To this I was very confused. He doesn't trust a digital indicator but he trusts a $.99 tape measure to check it. Strange...
Anyway, curious if anyone has one installed on their saw and what they think of it. Seams like a big time saver. One of the advantages would be when I put on a sacrificial fence I can just zero it out and have it measure for that fence, take it off and zero it out again for the regular fence. Any thoughts?
Re: Digital Readout for table saw fence
Alan in Little Washington (NC)
>If it is the Wixey, I have had one for over a year (production and beta). And you are right it is very accurate and can be easily and quickly zeroed (like the Wixey planer height gauge). It is also great for those who have weak eyes. The only negative is human nature- since it is accurate you spend time tapping the fence to the precise setting when you may not need that level of accuracy for every cut. What makes it better than the other digital fences on the market is that the readout/measuring unit is coupled to the fence with rare earth magnets so the fence can be removed and reistalled without losing calibration since the readout/measuring unit stays on its track.
Carlos Clarke
>I have the old Delta version. It has been sitting on the saw unused
for years because I can't trust it. When it works it is great.
But I find that repeated moving of the fence causes it to lose
position. I've seen it off as much as a quarter of an inch.
I've been playing with it again recently and I believe that
slight lifting of the fence when positioning it may be causing
it to jump the track. It may just be a matter of adjusting my
fence to move smoother along the track.
Tom MacGregor
>I keep a couple of good quality steel rules handy and have no problem whatsoever setting the fence quickly and accurately. I'd rather spend the money on more wood than on bells and whistles like digital readouts or laser sights on woodworking tools.
Larry in NW Ohio
>Paul I have one from Accurate Tech. and love it. I wouldn`t do without it. As someone said you have a tendency to tap it to .001 and kind of tough to do. Also if anyone is like me, if so I feel sorry for you, I really misread a tape rule so easy. But with a read out it`s harder to do. Larry in Ohio
Paul Woolson
>Thanks all for the replies. Larry, to zero it out, do you just butt it up against the blade? Also, have you measured a cut piece with a caliper to check for accuracy? What did you pay for yours (if you don't mind me asking). The one at Woodcraft was $150 which is enough for me to really think about it. Though the accuracy I need in guitars is down to the .001" so it might save a lot of fiddling.
Larry in NW Ohio
>Paul I`m not to sure but I think it cost a little over $200 but I`ll try to get more info for you later today. I have quite a few things on the to do list. Our last family border,son, is getting married in a month and have a few things to do. I have the wexly angle finder and that is also excelent, gets angles on tools dead on the first time. Try to check back a little after noon. Have a good day. Larry in Ohio
Re: Digital Readout for table saw fence *LINK*
Patrick Capobianco
>This the one I have and it works great.
http://digi-kit.com
Larry in NW Ohio
Larry in NW Ohio
>Paul I forgot to tell you that I run a board thru it and measure it with a dials and reset the read out untill they match. Larry
