Sharpening spiral cut router bits
C Paxton
>Would appreciate opinions on both whether it is worthwhile and whom might do a good job. Realize that profile will be changed slightly - a very minor concern for me.
Re: Sharpening spiral cut router bits
Just buy new ones in solid carbide
Re: Just buy new ones in solid carbide
C Paxton
>The reason to (perhaps) not do so is that sharpening a solid 1/2" costs $14, whereas a new bit costs ~ $60-80. Looking at sharpening 4 bits, so potentially saving $200.
These are solid carbide bits
C Paxton
Dale Lenz
Dale Lenz
>I've had mine sharpen by a local sharpening shop. Worked great, as you said, a few thousands difference was not a major problem in most work. I believe the sharpening guy told me it took a special machine. My local sharpening man is no longer in business, gotta find someone else, now.
Tom Stockton
>I also have my local place sharpen them. There are a couple of different ways they can be sharpened some places can only sharpen the cutting end and this works well for a couple of sharpenings but to have a real nice job done the flutes need to be done as well.
like you said it gets expensive to think of these a disposable.
Tom
Re: Have you tried using end mills?
Al Crandall (N.E. of Indy)
>I'm not sure exactly what the differences are between solid carbide router bits and solid carbide endmills, but they might be worth a shot. They certainly don't cost $60 to $80 each. Probably a degree or two less clearance behind the cutting edge and a slightly different spiral angle. Locally, a 1/2" diameter carbide endmill is $19.25 each. At Enco, a 1/2" solid carbide endmill with 1" long flutes will cost you $17.99 plus shipping. Also available are endmills for aluminum with a faster spiral for faster chip ejection which might also work well for wood. Available with 5/8" and 1 1/4" flute lengths, they are priced at $23.99 and $26.49 respectively. I've sharpened spiral flute endmills as part of my training, and it does indeed take a special machine. Nothing wrong with "regrinds" if properly done, but the savings aren't what you are projecting. Be sure to tie down the regrind shop on delivery time.
Larry in NW Ohio
>I have sent my sharpening things to Scott Whitting, who posts here once in a while, and does a very good job, the last time I sent some a few things and a spiral bit, to www.ridgecarbidetool.com and they also did a very good job. Nothing against Scott but I thing things from ridge were a little sharper. Larry in Ohio
