Harvesting Free Standin g Dead Charry Tree
>Good Evening Friends,
My #2 daughter Lizzy has a neighbor who must take down a cherry tree which died about 5 years ago. Trunk is between 18 and 20 incghes in diameter, and I'm not sure of trunk length. Could this wood normally be used for furniture? Lizzy was thinking about me making hope chests for everybody including her neighbor if the wood came my way from the mill. What do you think?
George
Re: Harvesting Free Standin g Dead Charry Tree
Rob Stokes in North Vancouver
>Domestic (fruit bearing) cherry or Black cherry?
If it's domestic cherry the middle is usually rotted out of those larger trees and the yield is virtually nothing. In fact, be really careful about bringing it down as the rotten parts can cause the tree to act in a manner other than what you're expecting when you fell it.
Be careful when limbing it too (assuming it's limbed while standing) as the bigger lower branches will also have rot in them.
If it's black cherry - I'm not familiar with them unless they've been squared off and run through a cash register :)
Rob
Keith Newton
>The last 3 cherry trees that I have gotten from urban settings have had such spiral grain, that it is only suitable for turning. Most of it had about a 45� slope.
This means that QS board have just as much end-grain as the end of the boards, and FS boards are really prone to twist as they dry. I am sorry I spent the time that it took me to saw it.
After 5 years, the sapwood is probably decayed and gone, which is OK, I usually try to mill it off of cherry, because it can dry and check within a day or two.
At 18 - 20", and If the bark is still on, 2" will be bark and sapwood, then take away a couple of inches for boxing out the heart, only leaves about 6" of good wood. That is the low end for size of what I am willing to deal with on my mill.
Dale Lenz
Dale Lenz
>Good evening George,
What I suggest to folks in your situation: poke the bole of the tree with an ice-pick or screwdriver and feel for punky wood. I agree with other's the sapwood is probably gone. There might be some bug holes on the outside heartwood. Obviously, if you sink the probing device, pass.
Enjoy
PS Yard trees are notorious for hidden metal.
probably yes
Bill Tindal, E.TN
>I don't know why but the wood I have seen from dead trees has a different and most pleasant look about it. Very mellow, especially cherry. There is some chance it may be wind shaken though but that will be obvious when its down.
probably yes
Bill Tindal, E.TN
Spiral grain.
Robin Corell in Atascadero CA
>I have no experiance with cherry but all the wood I use is milled from landscape trees. I ocasianally see a spiral monterey cypress or eucalyptus but they are the exception. My uneducated opinion is that it is something genetic rather than environmental. This would make sence since most landscape trees are clones and most likely many of the cherry landscape trees in Keith's are likely from the same wholesale supplier.
I have noticed that they always spiral with a right hand twist, or the same as a standard twist drill bit. Anyone from down under observe a diferent direction to the twist?
Robin Corell
Philip Duffy
>Col, I have been turning blanks of a wild black cherry that was dead for some time before being taken down and I got to rescue it from the fireplace. The wood is dry to a certain extent but still prone to crack. It is lighter in color than any previous cherry I have turned and looks quite beautiful when finished. I doubt it would be suitable for planks/furniture but it does make great looking bowls. A few diseased oak trees that I have worked have a crystal-like heartwood and the workability is very poor. I think my cherry has some of those same characteristics. Philip
>I was just reading "The Woodwrights Shop" last night where he talks a little bit about getting wood. Sir Underhill wrote about an incident where a large redwood tree fell down on a nearby property and he asked the owners about it. They gave it to the gardener I think, and Roy of course went to see the gardener. This man was going to cut up the tree for firewood, so Roy offered to trade him hickory wood in exchange for the redwood. The man refused to give up his redwood and ended up burning the whole big redwood tree for firewood. This is a great tragedy.
Free Standing Dead Charry Tree
Carmen
>George,
I've used quite a bit of locally cut cherry. It is certainly not the pristine lumber one would find at a supplier's. If the local log was sound when cut, there's usually quite a bit of curl and figuring, as sell as quarter-sawn grain in unexpected areas throughout the tree. Also, the grain might curve because the trunk also curved in different directions. So, getting down to usable wood takes some creative planning, and you'll certianly accumulate some kindling in the process. However, I've made toy chests, clocks, and other things with a lot of character with the wood I've used. I would hope that the tree you're considering still has much of it's wood in sound condition. Otherwise, I think you'll have fun using some cherrwood with character.
Carmen
