OT: Vinyl chemistry??
Rich Glisson
>I know there are some chemists here and I have a problem that I need help with. I have a number of Caradco double hung wood windows that are "dry glazed", meaning the 5/8" insulated glass is mounted in the wood sash using a vinyl gasket (pic below). Some brain-dead painters that I hired sprayed oil-based primer all over the gaskets instead of masking them. I put them in a bucket of paint thinner to soften and remove the paint, and the gaskets shrunk and stiffened to the point that they are unusable. I contacted Caradco (now Jeld-Wen) and they were utterly useless. They switched to "wet glazing" last year and no longer can supply the glazing gasket or tell me where I can find it elsewhere. They said I may need to buy new windows (thanks a lot!) I searched the web literally for hours and cannot find anything that resembles what I need, which has inside dimensions 5/8" wide and 5/8" deep. So....is there anything I can soak the gaskets in to restore the original suppleness of the vinyl? I'm afraid I know the answer, but am willing to try anything. Thanks!
