shop lighting question
David W
>My new shop space will have 14' walls. The ceiling will be white drywall. Are there any rules of thumb or sources I can go to calcualte the number of 8' flourescent fixtures I would need for good general lighting? I will have some specialized fixtures for task lighting. The total space is about 160 square feet. Thanks.
Re: shop lighting question
mdclor
>David,
I can't give you a rule of thumb except that more lumens are better, especially as you age. I would probably try to get about 125-150 lumens on my work surface, about 3 feet above the floor. If you go to a good electrical fixture store, they probably have someone on staff that can calculate your requirements. I have found this to be a free service if you buy the fixtures from them.
HTH,
Merle
Andre Mallegol
>Fine Woodworking had an article about 3-4 years ago that I followed. Their recommendations worked out fine although initially it seemed like a lot of fixtures.
Andre
yes
Bill Tindal, E.TN
>1 read article on lighting in Articles section of Woodcentral
2. Any large lighting store will have a program from GE that will determine how many lamps are needed to provide XX foot candles of illumination.
Ray Newman
>The article was in Fine WoodWorking, #154, Feb. 2002, pp 56-61.
Shop lighting math
wilbur
>Here's how I calculated my workspace lighting needs:
1. I want 75-100 foot-candles of light at my workspace, which is 200 sq. ft..
2. Multiply foot-candles by the area of my shop gives me 15000-20000 lumens of light total.
3. Throw in some fudge factors to account for the distance from the fixture to the work surface and the dust that will make the fixture less efficient, which I guesstimate is 50% drop in efficiency, and that works to 30000-40000 lumens that I need.
4. I used Philips T8 cool white 4 foot bulbs, which put out ~2800 lumens apiece. 10 of these is close to 30000 lumens. 14 tubes will get me 40000 lumens. This works out to about 5-7 2 bulb fixtures.
So far I have 5 fixtures up, and I'll see how things go before I add two more. I think I'll be adding task lighting, if anything.
Of course, you can change your desired foot candles to anything you want. The other main variables are your efficiency estimate, which will depend on your shop environment, and how many lumens the bulb is rated at.
What nobody has mentioned....
Lee Brubaker
>is that white gyproc doesn't stay white.....it yellows with age & if you have not painted the ceiling white before light installation you will wish that you had. Yellowed gyproc really soaks up light.
Lee
additional consideration....
Bill Tindal, E.TN
>you don't need that level of light everywhere in the shop and your target is on the low side for detailed work. Instead of targeting an average XX foot candles across the shop, the target should be an appropriate light intensity in the critical task areas and as little as 25 foot candles is sufficient for background. Consider that indirect sun is in excess of 500 foot candles. I have 200 foot candles at my bench surface and it is barely adequate for detailed work like cutting dovetails. Of course if one is going to supplement with task lighting or you have the joy of some natural light the lamp lighting requirements will be less.
Many of my lights are on pull chain switches so that I can turn them off unless I am working in that area.
Thanks and clarification
David W
>Those are all good suggestions. I see that my origianl note said my shop was 160 square feet. It should have said 1,600. Everyone was polite enough not to point out that I wouldn't need much light at all in a shop the size of a closet.
Re: Thanks and clarification
Dan Donaldson
>We just figured that it was 10 X 16 with 14 foot ceilings ;-)
Now, what do you mean closet? My shop ain't much bigger than that. ;-)
arw01
>For my shop of 780 sq feet I currently have 3 8' 4 bulb T-8 fixtures. There are two 4'bulbs on each end. With three of them in half the shop, I feel I have more than adequate light for all machine work and close measuring.
I plan to suplement at my bench with a desk arm type lamp for doing dovetails or intricate work.
The other side of the shop currently has no lamps, but I have on ready to hang from the ceiling in the next few days.
At 1600 square feet, you will need more than 2x what I have so figure 8 to 10 fixtures with 4 bulbs each as a minimum.
Alan
