OT - Electric lawn mowers, what do you think?
Dave Anderson, SoCal - From Home
>Since my abdominal surgeries a couple of years ago, I'm not supposed to do anything that will put undue strain on those surgery-weakened muscles.
Yesterday, I mowed my lawn with my gas-powered mower for the last time... As gas mowers are prone to do on occasion, it decided to be finicky and didn't want to start. After pulling the cord (and my guts!) so many times I lost count, I finally decided to replace my gas-powered lawn mower with electric.
Since this decision is health driven, price is not really a consideration. Is there anything I should look for or avoid with an electric mower?
Thanks and work safely!
Re: OT - Electric lawn mowers, what do you think?
Howard Norman-Prescott, AZ
>I haven't had an electric lawn mower for years, I don't have any lawn now so no need for a lawn mower. However, if I were in need of one now I would seriously check to see if one of the battery powered ones would have enough capacity to do my lawn. I have a friend in Phoenix that got a battery powered one recently and he is very happy with not having to use an extension cord. I recall when I used one years ago I was always cutting the extension cord. Seemed to cut it at least once per season.
They certainly are quite and start when you turn the switch compared to the multi pulls that a gas powered one will require on occasion.
Howard
Paul Woolson
>I used to have an old very basic electric mower. If you have a yard that is small(ish) and very few obsticles, I think a chorded mower will work fine. But if you have trees, shrubs and the like, I'd look at the rechargable ones.
I remember my grandpa having an extension chord that was specifically for his mower. I think it had more electrical tape on it than original insulation. He'd hit that thing a couple of times every season.
Larry in NW Ohio
>Dave Got a few sites for you. Go to www.myneuton.com or peoplepoweredmachines.com or tylertool.com and try bizrate.com Good luck and let us know what you buy, I`m thinking of going that way in a couple of years. Larry in Ohio
Al Stokka - Cambrige, Iowa
>Dave,
I have no help with an electric mower, but have you thought about an electric-start gasoline mower? You lose the fun of trying to start a stubborn gas engine, but you keep the power of gas.
Al
A.J. Hamler
A.J. Hamler
>I had one a few years back, and while I personally prefer a gas mower myself, I had no problems with the electric and found several pluses for one:
o They are lighter than gas-powered motors.
o They are extremely smooth and quiet.
o They are cleaner than gas mowers, with no gas/oil drippage or spillage.
o Far fewer motor-maintenance issues.
o No gas/oil smell where you store it.
o They start first time, every time at the flick of a switch.
o When storing for long term (winter), you don't have to worry about where to keep it because of flammability reasons. You can also hang it on the wall -- nothing spills out of it.
o You never have to run to the gas station in the middle of a mowing job because you ran out.
o You don't have to store gasoline in your home.
Downside, as someone up-topic mentioned (Paul, I think), they are best suited for lawns that don't have a lot of obstacles, and lawns that are more generally rectangular in shape. And, of course, it is possible to run over the cord -- although in the two years I had an electric mower, I never ran over the cord once.
A.J.
Happy Convert . . .
s.mackay@worldnet.att.net
>Once you go to Electron-burning mower You'll never go back ! Have'nt goofed with gas, oil, points, mixing,, throttle, plugs, pulling or stalling in years. Plug & play is the way, Baby ! And once you get " The Plan " on the pattern of how to move it around your yard flipping the cord its faster too ! Just don't pay too much. I think one lasts as long as the other. Nine years in this house and I just now bought my second one for a hundred bucks. This ones a B & D so we'll see.
Dan B
>I inherited a neuton battery operated mower last year. With 3000 sqft of mowing I still perfer the gas mower, but to just hit the front yard I go for the neuton. It is small, quiet, and light weight and is easy to store. If I remember correctly, I got at least four front yard mows, 1000 sqft each, out of a single battery charge, and it came with an extra battery as backup. Actually, I don't think I have recharged the battery yet, but I suspect it needs it by now.
The down side for me is the size, or width of the mower. I think it has plenty of power but it is limited in its width, requiring more passes than a wider gas mower. Also, the wheels actually extend past the blade housing requiring you to overlap your rows. The string trimmer attachment that hooks on the front of the mower is a joke in my opinion and never worked as advertised.
It is quiet, the first time I used it the neighbors thought I was putting down fertilizer due to the mowers green plastic appearence. If this thing had a set of headlights it would be the perfect after dark mower.
As someone else noted, the big plus is that you don't have to deal with gas, oil, noise, and tune ups. You can actually hang the mower on the wall during the off season. I would think this was the perfect mower for someone who had a smaller yard that did not want one of those old reel mowers.
Bill Howatt
>I've had both and there is no doubt the electric one wins hands down in starting, fuel storage, maintenance etc.
If you have a lot of bushes or obstacles the power cord can drive you nuts. Often with a bit of planning and experience you can minimize this.
Biggest problem is probably weather dependent. If you get a bunch of rainy days where you can't mow the lawn it will get long and thick and the electric just doesn't, pardon the pun, cut it!
Is your gas mower old? Modern ones are vastly improved in the starting department, IMO.
Bill
All good points
Curt Harms
>We've had a corded B&D since 1997 or so. The only maintenance issue is eventually the brushes wore out. I replaced them with True Value hardware versions. The way to deal with the cord is to start at the outlet(s) and cut out from there. We have quite a few obstacles and with some planning it's not a serious problem. Re power, keeping the blade sharp helps quite a bit. They're certainly not for large lawns but the no maintenance, no fuel aspect is appealing and they're quiet. The one we have has a rear bagger and mulching capability. If the grass gets TOO long, 5" plus power is an issue and I bag the long stuff. Not too much fertilizer helps ;)
We have a neighbor with a Neutron mower and it seems slick, You can't hear it, but does seem lighter in the power department than the corded B & D.
Curt
