Finishing question
Finishing question
Finishing question
Michael L.
>I am in the process of trimming out 3 bedrooms, new doors, casing, brown, base, and will be spraying white lacquer on all the woodwork. Anybody know if I can spray directly onto existing painted wood surfaces such as balusters, handrails, etc, without feel of it lifting. The existing surfaces would be sanded but not down to bare wood.
Michael L.
Trinity Interiors
Re: Finishing question
Keith Newton
>lacquer thinner is a pretty hot solvent, and will likely cause problems over oil-base, or latex, but should be OK over old lacquer, if you know that is what was already on there. You should do a test area before you commit.
Yes, if you do three things first
Michael Dresdner
>You can spray over old paint or finish if it is intact (no peeling or cracking evident) provided you do three things first:
1. Clean and degrease the surfaces. Virtually all surfaces in homes get airborne grease and silicone oil on them. TSP or any detergent will work.
2. Abrade lightly; either 320 or finer sandpaper, or the equivalent in nylon abrasive pads.
3. Prime the surface. Use Zinsser SealCoat for clears, or BIN under paint.
