Veritas - Innovation in Tools
OT - I'm tired of packing.... semi-rant.. (long)
>How can two people accumulate so much JUNK! This move has taken place over the course of a year. The first phase and the "big" move took place last year about this time. That's when we put the house on the market. I stayed here and worked. I took carloads of stuff up on the weekend. I thought that I was "making" headway.
Now it's closing time. Have to get the house (and shop) emptied. The shop is my fault - I'm a compulsive packrat. It didn't help that I took a couple of pickup truck loads of stuff out of my stepfather's shop after he died.
I've got to really, seriously declutter as I finish my new shop. I DON'T need all of this stuff. How many drills do you really need? I have at least three 1/2" and at least three 3/8" drills as well as the portable. Not to mention a couple of braces and a couple of egg beater drills. I've got three circular saws (one of which was mine originally). I've got a box full of files (various types) and rasps - that's a "book" box full. I can hardly lift it. How many of those do I really need? There is such a thing as too many tools.
Sigh.
Re: OT - I'm tired of packing.... semi-rant.. (long)
BobP
>JL I'm about to feel your pain ;>(
I too must clear out the shop in preparation for selling my current shop (with house attached overhead). Will be looking for a new shop with house attached in the next few months.
It is the prospect of having to get all that big iron out of the basement. Going down, one piece at a time isn't so bad. When you have to get it all out within a month or two, that's what hurts.
Gonna be without a shop for several month now...think I'm gonna need therapy :>)
Good luck on the final moves
BobP
Skillman NJ
Rob Sandow
>I'm in the process of this too. I'm putting it all in a POD, although I think I'll need a 2nd POD before I'm done. Last year I got an 11 cu. yd. dumpster and filled it with a lot of the junk I'd accumulated over the past 10 or so years of living there. Amazing how much stuff you have that you really just don't need and don't miss once you have purged it.
Rob
Todd O. Cronkhite Maine Native, Presently Away
>yup, you be right JL, I do think that there comes a point where you can have too much stuff. I've weeded out alot of stuff over the past few years and as was mentioned I don't miss it one bit. I can't bring myself to part with the numerous duplicate #3's 4's and 5's I have not to mention saws,chisels, brace's/bits, sharpening stones, and hand crank grinders tho. Other than that, I'm pretty much down to the bones in other areas. Matter of fact I started weeding out WWing mags just last night.
I don't like clutter, but it's a constant balancing act isn't it.
Organization is the key to clutter control--in the shop anyhow. As we speak I am fighting it my shop. I am completely re-doing my tool storage system----again. :~( I've got it nicked this time tho.
My current solution is simply not to buy anymore common saws, chisels, braces, 4's and 5's until I have a better storage solution for the duplicates already on hand. I've been applying this solution simply not by going to flea-markets as I used too, which, with Spring coming on, and new rust becoming available is very hard to do. ;~)
I have learned over the years of moving---military man--that less is in fact more in most cases. Remember, Quaility not Quantity.
Good luck with your move and your weeding out process. It's painful at first, but it does get easier once you realize, much against your solid beliefs that letting stuff go really won't kill you
T.O.
Addendumn *
>Also no more common spoke shaves and drawknives.
bottom line is that I have enough of the common stuff, and I ain't buying nothing else unless it's really something special, or Heavens to Betsy--something I need
As for your zillions of files, they could be used to make some nice knives if you'd ever care to try your hand at knife-making.--At least that's what I tell myself. ;~)
* I know this is the Power Tool side, and I'm talking Handtools, but the point is still the same IMO.
T.O.
Re: Some of the files are going to...
>John C. Campbell Folkschool - I'm sure the blacksmithing classes can do something with them :). I am in a quandry as to what to do with the rest of the "good" stuff. Yardsales don't really work unless you have a "critical mass" of stuff to sell. Maybe if I can talk my wife into parting with some stuff....
I have a rather large box of decorative "tins" of hers. Maybe we can have a big bake sale? The Longaberger baskets are definitely off limits though.
Jesse in New Mexico
>A fella here was in the same situation. Went to the monthly woodworkers club meeting with a pickup full of stuff, we pretty well cleaned him out.
Ted Wong
>I think all woodworkers can also be called tool and wood junkies. I know what you're going through. When I moved ten years ago I had way too much stuff. Ended up giving away several hundred Bd. Ft. of hardwoods. Selling all my machinery. It was still a painful move but unloading a big chunk of my possesions really helped the move go a lot easier than it would have if I tried to keep it all.
Larry Clinton At Frankfort (Central)., Indiana
>Been there - done that. Its real hard to rid yourself of useful items - even when your pretty sure you won't use them again. I raised 6 children, so when I was younger, didn't have much cash left to purchase tools. So what I did buy I kept and kept and kept. I did contracting work on the side so saved many odds and ends - sheet metal, short pieces of romax, pipe fittings, outlet boxes, screws etc. I accumulated enough of these that I couldn't find anything. Got to the point I would go buy something I knew I had cause it was just too hard to find. Had a huge "giveaway" rid myself of at least 2 pickup loads. Then when I moved into my new shop about 3 years ago, I found tools I forget I owned. I packed everything into my 30 X 30' shop, then decided to get rid of many. Like you I had 4 circular saws, 3 saber saws, 6 electric drills, 2 or 3 miter boxes, 1 bench top saw, 2 table saws (in addition to my Unisaw I purchased for the shop). I had one tool box full of screwdrivers - many junk. I started giving away tools to my sons, grandsons and a friend that really needs some. They were happy, and I have gotten rid of at least another truckload & 1/2. Still have too many but can't bring myself to part with more yet!
