How would you do this - Need Advice
Joe in a Cleveland suburb
>Hi folks.
Somebody asked if I might be able to do something for them as described below and in the picture. I am thinking one way would be to use a router, a straight-cut bit and some kind of jig for the router to run on. I have absolutely no clue how I would figure out where to cut, at what angle to cut and so on. I would greatly appreciate any advice, suggestions, and so on.
Below you see a tapered column. The idea is to cut a slice out so the column fits on the outside corner of this cabinet looking thing. I suppose the column would be set in so the bottom outside corner of the cabinet is about half way in to the column. So at the top of the column, because of the taper, it would only be in part way. Hope that makes sense.
Suppose you only get one shot at it and it needs to fit nice. This column was something the owner inherited from a Great Grandfather and you really don't want to screw it up. How would you do it?
Thanks.
Joe
