Tools I need to add?
Charles Jackson III
>Here is the tools I think I need to add if u guys have any more please add ur imput.
Power Tools
14'' Grizzly GO580 Bandsaw for cutting curves, resawing and cutting thicker curves.
10'' Makita LS1040 10'' Compound Miter Saw for crosscuting long boards, and for cutting trim.
Freud Thin Kerf Blades 40 tooth finishing blade, and a 24 tooth rip blade, for to get better cuts out of my Delta Benchtop Table Saw.
Freud 60 tooth crosscutting blade for ultra fine cuts.
I hope to get a ginder to.
Hand Tools
A new set of Footprint Beech Handle Chisels for all the fine work.
Some old Stanley Bailey Planes for flatting and smoothing rough boards, #4, #7, and 60 1/2 block plane.
Bevel Square for marking angles.
Footprint 1876 160101 Beechwood Mortice/Marking Gauge for sorceing cuts, for dovetailing by hand.
More Bar Clamps, and maybe a couple hand screw clamps, and some quick grip clamps.
Johnson Level J36 36-Inch Aluminum Straight Edge for making sure my boards are flat.
Cutting Guide for my circular for breaking down plywood.
always need more sandpaper, drill bits, spade bits, and sharpen stones.
Re: Tools I need to add?
>Dovetail saw - I saw the marking gauge, I didn't see the saw.
#5 plane - a good jack plane is a nice thing to have.
Winding sticks - you may be able to make your own.
Bevel boss or something similar to set the angles with.
Jesse in New Mexico
>Hey Charles,
Without knowing what kind of woodworking you plan to do, its hard to tell if the list is complete or appropriate. The main big ticket items that most of us have that are not on your list are a jointer and a planer. I see you plan to get some planes for milling your wood, but that is slow and hard work. Anyhow, I have made some notes in your list.
Power Tools
14'' Grizzly GO580 Bandsaw for cutting curves, resawing and cutting thicker curves. DON'T COUNT ON A 14 INCH SAW RESAWING LARGE STOCK
10'' Makita LS1040 10'' Compound Miter Saw for crosscuting long boards, and for cutting trim. WILL PROBABLY NEED TO UPGRADE THE BLADE FOR SMOOTH CUTS - THIS IS SOMETHING HAND TOOLS DO WELL, MIGHT USE THE $$ TOWARD A PLANER...
I hope to get a ginder to. CONSIDER A SLOWER SPEED (1725 RPM) OR LESS IF YOU WISH TO USE IT FOR SHARPENING TOOLS
Hand Tools
Some old Stanley Bailey Planes for flatting and smoothing rough boards, #4, #7, and 60 1/2 block plane. PLAN ON SOME SERIOUS ELBOW GREASE TO TUNE THEM UP. LOOK FOR FLAT SOLES AND NO DINGS AROUND THE MOUTH
Johnson Level J36 36-Inch Aluminum Straight Edge for making sure my boards are flat. JL'S ADVICE ON WINDING STICKS IS GOOD HERE.
EASY TO MAKE THIS IN THE SHOP.
always need more sandpaper, drill bits, spade bits, and sharpen stones. IF YOU DON'T HAVE STONES ALREADY, DON'T BE IN A RUSH TO BUY THEM. TRY SANDPAPER ON A PIECE OF GLASS FIRST, AND PUT THE $$ TOWARD A PLANER ;^)
DON'T KNOW IF YOU ALREADY HAVE THEM, BUT YOU MAY NEED A GOOD RULER (4R), A GOOD SQUARE (MOST AREN'T), A GOOD JAPANESE SAW, CARD SCRAPER, SPOKESHAVE, AND MAYBE A HONING GUIDE.
HOPE SOME OF THIS HELPS...GOOD LUCK!
Your #1 tool should be WoodCentral!
Joe in a Cleveland suburb
Charles Jackson III
>I have a framing square, combination square, 1200/4000 water stone need to get a 8000 grit stone. here is a list of what I have
I have a Delta Benchtop Table Saw, Skil Circular Saw, Black and Decker cordless and cord drills, Black and Decker Finish Sander , Hitachi M12VC Variable Speed Fixed Base Router, and a Black and Decker Jigsaw Hand Tools, I got a basic clamp set, hammer, a combination and framing square, tape, mallet, drill bits, router bits, nail set, jig saw blades, a small straight edge, back saw,some cheap chisels, and 1200/4000 combo sharpening stone.
>Probably the reason I got into woodworking was because of Fine Woodworking magazine; I now subscribe to Popular Woodworking, which costs less and is a much better magazine. And woodworking books. Ernest Joyce' Encyclopedia of Furniture Making is one book I have literally worn out the binding on. And of course nowadays as mentioned Woodcentral is the best tool to have. A bandsaw is a nice addition to any shop; you will always find uses for it, and it is a little safer to use than a table saw.
A few more to the list....
>I'll add some ideas:
A shoulder plane
A cabinet scraper of some sort.
A dial caliper
A dead blow mallet
A scratch awl
And a tool that is very handy is a good workbench!
Have fun tool collecting!
Tom
Dave Morris
>Get a set of transfer punches. I bought a set years ago that I find myself grabbing on all sorts of projects. Graduated by 64th's, from 3/32" to 17/32". They work great for sizing existing holes too.
If you plan on doing any dowel work, a set of dowel centers is very handy as well for marking locations so the holes line up.
Dental picks for teasing bits of glue/cleaning tiny hard-to-reach spots in corners.
Dave-- who is trying to think of more inexpensive items, but the coffee hasn't kicked in yet
Chuck Lenz
>It's kind of a rediculous question. In my 30 years of woodworking I've bought what I needed at the time and I'm still buying.
Lee Gordon
Lee Gordon
>I think you and I are suffering from the same affliction: it seems like we're both more interested in obtaining new tools than in actually doing something the ones we already have. So please don't be offended by this advise, because it is meant as much for me as it is for you: forget about loading up on new tools and just get out into the workshop and make something. And not just start something; finish it. If you get to a point where you absolutely can't continue with the tools you have on hand, you'll discover what's the next tool you need to add to your arsenal. You'll then be able to come back here and ask if you should go with Brand A or Brand B or Model 100 or Model 200.
As I said, my recommendation is aimed at myself as much as it is at you or anybody else. Now I feel properly inspired to get out to my own workshop and finish the four or five half-done projects that are out there.
Agree with this advice for Charles.
John Pappas
