OT - Chevy TSB - HELP cannot find - Ending
Terry Alexander
>We do have a happy ending.
The TSB said to squirt some jell on the disc pads to get rid of the brake squealing. So....that's what the dealership did. Didn't work. So they replaced the front pads and rotors (BTW.....tis a 2007 PU purchased Veterans Day last October.....13,000 miles on it). They test drove the vechicle again and still had brake noise. Replaced the rear shoes. No noise at all.
It is obvious driving the vehicle now that there was a problem from the "git go". The truck handles better than it has when it was new. There is not any "throwing you through the windshield" on the first brake of the day.
I don't think it's fair to publish the name of the dealer as they were bad....and good. We just should not have never had to go to through the extreme aggravation to get resolution.
BTW.....GM called day before yesterday and said: "Let me see if I understand your position. You have no intention of taking possession of the vehicle until the problem is solved. Is that correct?". We (obviously) said "Yes" and I think that put the burr under the Service Manager's saddle.
Yep...we'll go back.......uh........they KNOW us now.
Thanks for all your responses.
Terry Alexander
Re: OT - Chevy TSB - HELP cannot find - Ending
Ken Oakley-Sunny St. Cloud, Fla.
>My grandfather always told me " The squeaky wheel gets the grease". It is proof positive in your case. Bet the dealer bends over backswards to listen to you now.
Joe Pack
>Glad everything worked out for you, Terry.
Their is still a problem with the service department/dealer, though. You got results because you were persistant and insistant, and you would not accept their attitude and incompetence. What about the larger percentage of people who are intimidated in the first place, or accept a dealer's word as gospel. People like my wife, sister, sister-in-law, inexperienced son.....would be taken advantage of by a dealership like this. They satisfied you because you were mechanical enough to challenge them, and would not accept less than having your problem corrected. The same jerk still works there, and will do the same thing to how many other customers?
Some windmills are worth tilting at.
Matt Robinette, Mt Juliet Tn
>On new cars and trucks the rotor needs to be turned while on the car. The noise is comming from vibrations when the pad and rotor are not flush with each other. If after proper turning of the rotors there is still excessive sound it could be bad bearings or even bent spindles.
You can try Pat Goss at Goss-garage.com He knows as much as anyone about cars. Or try click and clack the tappet bros. at cartalk.com they may not fix your problem but they may make you laugh about it.
