benchdog holes
Joey, Ct.
>Finally finishing my workbench top 108x29 maple. I need to drill or route 3/4" holes for dogs, but can't remember how I did it on my last bench. One mistake and I'll ruin it. Please advise. Thanks Joe
benchdog holes
Joey, Ct.
Re: benchdog holes
mike mcnerney
>I've had good results making a hardwood bushing, on the drill press 3" long or so, & fixing it to a plywood base. I assume you will be using a good quality twist drill or one of those ship augers. You may be able to get a 3/4" i.d metal bushing from your local bearing supplier.
mike in ottawa
What he said, plus....
Jesper, Denmark
>Start the dog hole with a forstner bit to get a nice clean entry. Finish the rest with a Bradpoint bit or other fluted bit, so you get support all the way through from the busshing you made.
Re: benchdog holes
>I used a good ole Brace and Bit. You can't beat it for this kind of work. Don't have one, they are really cheap at the flea mkt. I've picked up 2 Brace's, one with ratched and one without, and 2 different sets of bits.
Re: benchdog holes
Joey, Ct.
>Thanks for the advice. I have some very special augers I inherited, so I will gladly take advantage of the suggestion. The bushing and plywood base should keep me on target. Joe
Re: benchdog holes
Diz
>I used a plunge router w/ 3/4"bit. My router bit didn't go all the way through, so I finished with a forstner in an electric drill.
Re: benchdog holes
Joey, Ct.
>Diz, Now that you mention it, I used my plunge router for my last benchdog holes. Probably even finshed up with a drill. I'll use a straight edge as a guide. Thanks Joe
