ADVERTISE HERE - FREE TRIAL
1 1/4 - 8 Nut
1 1/4 - 8 Nut
1 1/4 - 8 Nut
Jon Rouleau
>Does anyone have a source for 1 1/4-8 tpi nuts? I was reading the article on making a Longworth chuck and althought the article talks about using a nut to make this, there is no source listed as to where you might be able to get these nuts. Can anyone help?
Re: 1 1/4 - 8 Nut
McMaster-Carr, MSC, Grainger, Enco, etc
Ray Thompson - Middletown,IN
Re: 1 1/4 - 8 Nut
1 1/4 - 8 Nut is a standard high strength thread
Forrest Addy
>A 1 1/4 - 8 nut is a standard high strength thread but not a UNC which is 1 1/4 - 7. These threads are usded in steam plants, high strength structural bolts etc.
So specify firmly that you wish a 1 1/4 - 8 thread to comply with your spindle configuration. By the way these high strength nuts are heat treated and if welded should be welded with care and some pre-heat. Because of their carbon content I suggest welding them with 308-18 or its TIG wire equivalent.
Got a buddy with an engine lathe? Better find one if you haven't.
Re: 1 1/4 - 8 Nut
Re: 1 1/4 - 8 Nut
John McGaw
>When I lived in Anchorage, Alaska and needed some 1-1/4X8 nuts and threaded rod I just went down to one of the local industrial hardware suppliers and bought them off the shelf. Items like this aren't your standard mom 'n pop corner hardware store items but they will be found anywhere any sort of industry exists.
Re: 1 1/4 - 8 Nut
Nuts!
Phil Joines Krum, TX
>I was going to sugest geting a hand tap to make your own faceplates untill I checked the prices. The lowest (at J&L Industrial) was $58 up to $165 at MSC. Two years ago I got one for $35. You can get a lot of nuts for that.
Re: 1 1/4 - 8 Nut
Re: 1 1/4 - 8 Nut
Rick in Colgate, Wi
>I was looking for the same size nut a while back, if you can find them they are not cheap and good luck finding a place that will sell you just one!
Grizzly Industrial has a threaded insert item G3167 with the 1 1/4-8 thread in it but the OD is round. I bought some of those and ground some flats on it for a wrench to fit. Welded them to round steel plates for my lathe.
Re: 1 1/4 - 8 Nut
Re: 1 1/4 - 8 Nut
>McMaster-Car # 90521A275 - grade 2H price $11.95 for pkg. of 5.
Grainger # 1XA53 - grade 2H price $9.95 for pkg. of 5.
These are hard to find even in the catalogue because you must specify the grade 2H for them to show up in a search.
If you are using these for a lathe, remember that they do not have a thread relief cut which means that the nut will nut turn on all the way to the spindle's shoulder. That will cause some instability in the mounting and produce vibration in the workpiece. Some people use a washer between the nut and shoulder, however most washers are stamped rather that machined with parallel faces, and so will cause some inaccuracy. You can, however, cut a thread relief into the nut with either a HSS tool bit or a small dremel-type grinding burr.
Good Luck
Re: 1 1/4 - 8 Nut
Re: Nuts!
mike hamilton
>If you want to cut threads in wood nuts, Beall has taps and sell them at their site and through Woodcraft. 1 X 8 was under $20 and 1.25 X 8 was mid-twenties.
Regards,
Mike Hamilton
Plainfield, IN
Re: 1 1/4 - 8 Nut
I Wrote the Article
Garrett in Victoria BC
>Hi John
You can use a small face-plate. I used a nut because I had some. (The local fastener shop had a box of them that had never been picked up by the customer, and I bought a bunch for a dollar each.)
It's a fun project and a very handy tool. Hope it turns out well for you.
Cheers, Garrett
