Formica
Formica
Formica
Guy Kroll
>Can Formica, be glued to Formica. Wife wants to change the top on the bathroom vanity. I want to go with wood but she wants to replace with Formica. It has Formica on it now, not sure if I should make a new top or if I can just glue a new piece of Formica on top of the one already on it??? Need some help with this one.
Guy
Re: Formica
Re: Formica
Grant Smith
>Not sure, doubtful that it would adhere well. Might try loosening the old formica with either a heat gun and a putty knife, or an iron. I have had pretty good luck doing that on smaller projects with formica on them.
FWIW,
Grant in Iowa
Re: Formica
Re: Formica
Hal Smith
>I have been told by those in the trade that it's the most common way to resurface countertops and that it works just fine. Haven't tried it though. Suggest you talk with someone in the business for opinions. Good luck. Hal
Re: Formica
Re: Formica
Kneale Brownson in Northern MI
>Scratch up existing formica surface and you should be able to adhere the new stuff OK.
Re: Formica
A qaulified Yes
Gary Camp - Bend, Oregon
>I have done it with good sucess in a comercial setting. I must be clean, like very clean. When you think it is clean enough, clean it again. No Soap residue. Scuff sand with 80 grit or coarser and glue it up. I even used a water based contact cement. In most cases however, I would prefer to make a new counter top out of 3/4" MDO and start fresh. I just can't bring myself to use particle board products under lam in situation where sooner or later water will get in.
MDO around here is about $50 a sheet, so for most counter top projects you're only spending another $100 bucks or less. Maybe I've had the particle board tops "blow up" at work to many times. In kitchens, bars and bathrooms there is no such thing as dry, at least in my opinion
glc
Re: Formica
It is done all the time
Neal in San Jose
>Piece of cake. Lightly sand the old formica to give the contact cement something to grab and remove ALL the dust, dirt, grease, etc. Just make sure you aren't building in a problem, like rot around the existing sink, etc. Try to line up any seams that may be needed with solid areas (in other words, no seam over a seam).
Re: Formica
Is it called reformica? ;)
Re: Formica
Yes
Ted Wong
>Belt sand the old surface, vacuum, apply contact adhesive, apply new surface.
Re: Formica
Re: I am ;)
Guy Kroll
Re: Formica
Re: Formica
wes bischel
>As others have said, it can be done. In the kitchen it can be an issue due to hot pots etc. being set on the counter and causing the contact cement to de-laminate. In the bath it shouldn't be an issue.
Good luck with the project,
Wes
Re: Formica
Re:Thanks Everyone.
Guy Kroll
