REAL MILK PAINT
Crooked biscuits
Crooked biscuits
Crooked biscuits
Pat Evans
>I have an Elu biscuit jointer, circa 1987, in which the blade is not parallel to the face. I can find no adjustsment to compensate for this. I've tried putting washers as shims between the faceplate and the body, but it's nearly impossible to get it right on. Instead of biscuits helping align parts, they misalign them. Has anyone else had similar problems with a biscuit jointer? Any suggestions for remedies would be appreciated.
Re: Crooked biscuits
Neal in San Jose
>I have the same ELU with the same problem. I hope someone has a fix, because I gave up on mine and it is just gathering dust on a shelf. I bought it used, and it didn't take long to figure out why I got it so cheap!
David Yoho
>Pat, that IS an old biscuit joiner. I haven't heard that brand name mentioned in a long time. If you're planning to use it for that student desk project, I think a new biscuit joiner is in your immediate future! There are a good number of biscuits used in it and it's critical for alignment to have them located properly.
David
Elu=Dewalt?
HC Sakman
>Is the same model as Dewalt? or is it the one with a side knob? nevertheless, there must be a way to align it properly, otherwise it defeats the very existence of the tool.
Chico...
Rod Peterson -- Ormond Beach
>> I have an Elu biscuit jointer, circa 1987…Has anyone else had similar problems with a biscuit jointer?
Your query triggered a long dormant memory of a post on the subject in rec.woodworking, a usenet newsgroup, so I did a search and came up with a similar query to yours. I couldn't find the source the poster cited in his response, but fortunately, the whole text of the source was contained therein. I'll try to color code it so you can tell who's who:
(post from 11 April 2004)
Here's a post from 3/5/2000 titled "DeWalt bisquit joiner off kilter" and a follow up post
Mike Farleigh wrote a message on how to tune up your dewalt biscuit joiner a couple of years ago. I've copied it below. Fixed my problem.
Greg
Here were the steps I took:
  1. Set the fence to 90°. Take the head off your best combination square, and make sure the fence is truly 90° to the face of the unit. If off at all, loosen the screw on the pointer and set the pointer so that the fence truly is at 90°. Re-tighten the screw.
  2. Set the fence to 45°. Use the 45° side of your combo square head to make sure it's truly at 45°. If you did step one right, only a defect would cause the 45° test to be off.
  3. Using a small, very accurate rule, make sure the opening where the blade protrudes was machined square. Make sure the bottom of the opening is exactly the same distance from the bottom of the unit at both ends of the opening. Then make sure the height of the opening is exactly the same all the way across. If anything I've mentioned in this step is off, the unit was not machined right and I'd consider it defective.
  4. Now, and only now, make the adjustment which was way off on both the units I've had: set the fence back to 90° and make sure that the top of the blade opening is exactly the same distance from the fence at both ends of the opening. If it's off (and I'd bet it is), slightly loosen the screws on the front of the unit, at either side of the blade opening (not the anti-skid pins, but the screws right next to them). Move the whole casting up or down on whichever side is appropriate, until the blade opening is exactly the same distance from the fence all the way across. Re-tighten the two screws.
    Be patient, this step was tedious and took a few tries until I got it just right. After the screws are tight, re-check the distance-to-fence to make sure nothing moved during tightening.
  5. Now, make sure everything is good and tight. Grab a piece of scrap wood, and set the fence height adjustment to, say, 3⁄8" (it's not important where you set it, as long as you set it in one place for these adjustments) Lock it down and leave it that way.
    Now, carefully, make a test cut. Mark the top of the wood, so you know which side the fence was against when you made the cut. Now take your small rule, and check two things:
    1. That the edge of the cut is precisely the same distance from the top corner of the board all the way along the edge of the cut. If not, then you need to revisit step 4. Most likely, your blade isn't absolutely square with the blade opening (some of you thought I overlooked this, didn't you?). However, you should at this point not be off more than 1⁄64" or so—now you'll really be splitting hairs as you revisit the adjustments in step 4.
    2. That the center of the height of the cut is exactly 3⁄8" (in this example) from the top corner of the board. If not, then the height adjustment scale on the side of the unit needs to be adjusted. This is the easiest part of the whole process.
I know this is a lot, but remember it's a one-time process if done right, and yields what I've found to be a remarkably accurate tool. Once it's all set and tightened, there's nothing as far as I can tell to come back out of adjustment—unless and until parts start wearing that would need repair service anyway, like gibs or the sleeve bearing in the gearhead.
The other adjustment, which I didn't need to make on either of my units, but which is mentioned in the manual, is the depth-of-cut. This is more or less a no-brainer.
Sorry for the length of this, I just thought it odd when I went through it that nobody ever talks about it and saw this as an opportunity make a contribution.
By the way, DeWalt will send you a manual and parts list free (I think) if you call them at 1-800-4-dewalt. Good luck!
Mike
(follow up post)
A faster way to check if a biscuit slot is parallel is to cut one in the end of each of two long sticks (as if it were the first of many slots to edge-join the two sticks). Put a tight-fitting biscuit in the slots and squish the two pieces together. Any deviation from parallel will be doubled by having two slots, and magnified by the length of the sticks.
I love the internet.
Rod
Elu=Black & Decker
Pat Evans
>This is an Elu Model 3380 Jointer/Spliner. You can see pictures of one like mine that just sold on Ebay for $264. Man are they going to be disappointed!
The blade can be adjusted up or down in the guard opening, but there are absolutely no adjustments to align the blade with the opening.
Thanks for the response Chico, but after seeing what sold on Ebay, this one will be listed there shortly.
Thanks Rod, but...
Pat Evans
>this is not the Dewalt unit. I appreciate the effort you went to, but none of the adjustments described in the post are applicable to the Elu.
Couple things...
>First, the old Elu machine is a pivot-point mechanism whereas the DeWalt product is more of the Lamello design, with a plunge instead of a pivot.
Also -- and I have seen this in biscuit joiners of all types -- the relationship of the blade to the fence isn't always parallel, because of sloppy tolerances in the machining of the fence and/or any interfacing parts. It is more common than you would think.
The trick is to exchange the defective unit. No amount of shimming is worth the effort. In the case of a 20-year-old tool, I'd say it's all over.
Now, the big question is, how far out of parallel is it, and when you compound the opposing errors, is it too much to allow you to close a joint? If not, you can live with the discrepancy, but it's not an ideal situation.
Re: Couple things...
Pat Evans
>"In the case of a 20-year-old tool, I'd say it's all over."
Ellis, even shimmed I can't get the biscuit slots close enough to flat not to affect the alignment of parts. I was prepared to say "it's all over" until I saw the same unit sell on Ebay for $264. Guess where mine will be listed shortly.
What you may not know…
Well, A) it was no trouble, because I've been needing to get that info into my system eventually anyway. 2) this was the hazard in not knowing what model number you were dealing with. While the 3380 (what I also have identified as the 2278 in my Norm's Tools page—Norm used that tool for three years in the '90s) never made it into the Dewalt camp when Black & Decker acquired Elu, the 3379 (which I own) did. It became the Dewalt 682. That's why I needed the info in the first place. Sorry it doesn't seem to be working out for you.
I can't account for why I have 2278 for that and 3380 seems to be the popular nomenclature in recent auctions. I had some accurate information at the time I made that ID—probably around 1996—but I have no idea from where, now.
Rod
