Rockwell/Delta Planer
Wade
>Anyone have any input on the Rockwell/Delta 50-651 13 inch planer? It seems to be well outfitted with a pully drive motor setup, as compared to the little universal motors that the newer and more portable units are coming with today. Any feedback or words from those experienced with this model would greatly be appreciated.
Thank you,
Wade
Re: Rockwell/Delta Planer
Keith Newton
>I have never owned one of those myself, but a couple of my old shop-mates had them. Neither were very good at tool maintenance, so I may not have the best opinion of them.
At their best, they never cut as good as the new portable planers. I think it is due to a slower RPM, fewer cuts per inch. They may have had a faster feed rate, but only half or less KCPM.
R. Lance in G.R., Michigan
>Since you're not getting a lot of response, I thought I'd give some input although I don't own this exact planer. Wish you had a picture of the planer in question. I do have a Delta 13" planer that came out after the Rockwell version....it is very heavy and the bed is stationary while the motor/cutter assembly adjusts up and down much like the current 15" Delta models. On the tool (vs) toy scale, this is definitely a tool....lots of power and two speeds for feeding stock. I do a lot with QSWO and have no problems with oak or any other wood. I built some infeed/outfeed tables and strongly recommend that for the planer(adjust the end of the outfeed table's height and eliminate snipe). I'd ask to run some boards through tis planer before buying to eliminate any doubts you may have....also contact Delta to check out parts etc. Good luck.
