PVC piping question..
>I am busy packing up shop (BTW, don't use blue tape, it doesn't do anything to hold things together).
So, I took the sawsall to the 4" PVC DC system, to get it out from where it was in the joists. The new shop will have galvanized ducts, so I won't need the PVC. Any foreseeable use for the pipe? I cut well on the sides of the joints, so it could be joined together later.
Re: PVC piping question..
AJ in Ohio
>If you garden three inch lengths are great to keep cut worms at bay. I've got about a hundred of them.
Mini-water slides
>When we replaced the 4" PVC with 6" PVC in our yard, we had 40' or more of old 4" PVC pipe that we were going to throw out. I was just about to cut it into 4' lengths to put in the trash, when I decided to slice them in half. The kids took them and using various rocks, bricks and other things, and built a miniture water slides in the backyard. They spent hours and hours with the garden hose making long water slides when the water pran down one and poured out into another. They rolled tennis balls, glaf balls, ping pong balls, down with the water.
They learn alot about gravity and had a great time.
So if you've got any young neighborhood kids, you might want to consider that.
In an age of instant premade everything, it was really nice to see the kids make something themselves out of junk.... the way we used to make things when we were kids..... it involves imagination, which today's kids are lacking.
Happy Woodworking!
Re: Cut 3/4-inch lengths
Al Stokka - Cambrige, Iowa
>Cut 3/4-inch lengths, sand the cut smooth, and give them away. They make great forms for hamburger patties.
Summer picnics and backyard BBQ's are just around the corner.
Al
Re: Mini-water slides
Guy Kroll
>Great idea Mark, and no BATTERIES !!!!!
Guy
That's NO good.....
>4" PVC will give you hamburgers that are less than 4" in diameter.
You gotta go with 6" PVC or larger! C'mon!
Happy Woodworking!
Re: That's NO good.....
Dan Donaldson
>A good hamburger has to be at least half a pound ;-) If I am going to die from all of the cholesterol, at least I want to die happy and full ;-)
