one-sided veneering--final report
Wayland
>HI gang-
Thanks to all who responded to my earlier posting on one-sided veneering. I decided to be stubborn and cheap. Stubborn in sticking to one sided, cheap in not buying any of the great new glues out there that are supposed not to cause warping.
What I did was to just use regular titebond III and to compensate by warping the wood in the opposite direction during glueup. I put a 1/4" stave under the 24" long panel to bend it convex while the glue was curing. When it came out it was pretty straight, but with a few little ripples caused by the wide-jaw clamps I used at the ends. Because it was convex, I had a little trouble getting the veneer clamped down to the 1/2" baltic birch base, and had to resort to the steam iron technique post facto. One trick that helped a lot was to wet the face of the veneer with water so it wouldn't curl while I was getting it clamped up at least. I had to put several cauls across the face and it was a little tricky getting them clamped down without distorting the assembly in unfavorable directions. And for some reason the seam between two book matched panels was not straight, despite getting it straight before starting. Thus I had some gaps of up to about 1/32" to fill. The veneer was pretty thick (about 1/16") so I might have been able to butt join it before hand to prevent this but I didn't know it was going to happen.
Again, thanks to all. Next step is walnut edging (BTW the veneer is 1/4 sawn sycamore) and after I get it finished, I post a picture.
Wayland
