A55 Smoothing Plane
Scallops - It Can't Be This Hard!
Ken Krawford
>I'm trying to make the scallops shown on the table below. Short version of a long story - using a compass, nothing I've tried works.
Can anyone help? Thanks.
Re: Scallops - It Can't Be This Hard!
Use Coffee can as template
Tim Greif - West of Chicago
>I've done similar scallops using different size coffee cans (or lids) as templates. Just play around with the layout until you like what you see.
Doug in Denver
>You have not made it clear why a compass is not working. Anyway, if you are trying to make those exact scallops, put something behind them and trace them. If you just want scallops of that radius, you can still trace them, or figure out the diameter if they were a full circle, then cut one full circle template to use. Or just experiment with round objects around the house until you find one close.
Oh, wait....
Doug in Denver
>Is that a catalog picture? Then I guess you can't trace them!
Ken Krawford
>I could be wrong, but I think that the scallops are NOT an arc from a perfect circle. When I use a compass (or cans for that matter), the center arc looks short. The points labeled "A" & "B" are not as high as the outside.
Ernie Miller
>If it loos short move you cinter point down or move it up and use it as an accent. just play with it on paper untill you get somthing you like.
Simple math problem
Virgil Johnson
>If you know the height and width of the scallop you can figure the radius.
C=Width H=height R= radius
R = C squared + 4 times the height squared divided by 8 times the height
Re: They are circular
Al Stokka - Cambrige, Iowa
>Ken,
The centerpoints of all three arcs are on the same horizontal line.
Divide the distance between the table legs by four. I'll call that distance "X." Use one-half of X to locate the first circle's centerpoint. Centerpoints two and three are X away from the first centerpoint. Draw three arcs (You have to play around to find the coorrect diameter.
Al
Re: Wouldn't you divide by six?
Al Crandall (N.E. of Indy)
>If all of the arcs have an equal chord, then each chord would be 1/3 of the the scallop board's length. Arc centers would be located perpendicular to the chord at its mid point, or 1/6, 3/6, and 5/6 of the scallop board's length. Yes?
Divide by 6
>Divide the front by 6 by drawing 5 vertical pencil lines.
Draw horizontal line to indicate bottom of each curve.
Draw horizontal line a bit higher up to indicate where curves will intersect... the peak of each cutout.
Use an ajustable compass or a bunch of jar lids, etc, using the lines as a refernce until you get the look you want.
Happy Woodworking!
Re: Well, of course.
>I think faster than I can type. I should have typed divide by 3, not four. Then, dividing the number by two would determine the placement of the first centerpoint.
If I had typed what I was thinking, we would be saying the same thing. Thanks for catching my error.
Al
>ooks like three coffee cans would do it
Don Henthorn
>but the outside curves change to a gradually larger diameter. You will probably have to free hand that part of it or get a French curve to get the right shape.
