belt size Delta 14" bandsaw?
Dave Rice
>Can someone please tell me the correct belt for a Delta 14" bandsaw. It's actually a Rockwell 28243 model that I just picked up used at a garage sale with no belt or book with it.
Thanks a lot!
Re: belt size Delta 14" bandsaw?
Russ Babbitt Jr.
>My 14" Delta takes a 93 1/2" without riser. With riser 105"
Marc Rosen
>Hello Dan,
I just measured the belt I removed from my Delta 28-243 and it is 43 inches circumference. There is a catalogue number 49-034 printed on it. Almost any V-belt would fit so if you were to run a string (or tape measure around your pulleys you'd have some info to take to your local automotive supply store )but before you reinstall a V-belt you may want to consider using a link belt instead. I've replaced two V-belts with link belts and I feel that the saw runs quiter and smoother, just the way the advertisers descibe it.
Marc
Marc Rosen
>Sorry Dave, it looked like "Dan" so early in the morning. And where you referring to the drive belt or the blade length as how Russ had responded?
Marc
Dave Rice
>Thank you,
I emailed the gal who sends the manuals for free, but wanted to see it run before I receive the book. Had to go to DeWalt to get it.
Dave Rice
>Thank you Marc and good morning!
it didn't have a belt. Saw looks to be very lightly used and completely stock except for the added rust.
Have been this route before and have yet to get the right belt the first trip to the store. i apprexiate the information!
Had a band on it which i polished the light rust from the places on the sides where it was rusted. Is fairly sharp so good to go, for a test.
Oooops, thought you meant blade...
Russ Babbitt
