OT---Spring steel vs. regular steel
Gary Evans Tallassee, TN
>Hi all,
My brother-in-law is having a heck of a time finding some 1/8"x1 1/2" spring steel to make some springs for a quarter-midget that he is restoring. Picture follows.
My question, for those of you with a metalurgical frame of mind:
What gives "spring steel" its properties? Is it the recipe, or is it the tempering? If we could buy some 1/8" steel strap and temper it, we might be homefree.
Thanks,
Gary
Re: OT---Spring steel vs. regular steel
ken
>Sorry no can do.I can't quite remember as to how it is made,but you can't make it,Sorry and I don't know if you have worked with spring steel but if you weld it or heat it,it can become brittle and break on you.So if you have to weld it,have it done by a professional.
Good luck
Ken
Can't make a silk ear from a sow's purse..er
Ray Thompson - Middletown,IN
>something like that. Spring steel has a different formula, probably in the old race car maybe high carbon steel springs.
Ray
Try an import car wrecking yard
Phil Joines Krum, TX
>There should be some 1/8" thick leaf springs.
Look for a specialy steel supplier. A spring shop
Forrest Addy
>Look for a specialy steel supplier. A spring shop such as is found in the yellow pages of most any largeish city will have access to suppliers.
You can't just order spring steel and bend it to the config you want except for gentle curves. For eyes and such you have shape it hot and then heat treat it. For that you need the uniform heat that only a heat treating furnace can give you. Better farm out the master leaf. The other leaves can be arched cold by hand.
Paul Waddle
>Spring steel has 1% carbon (among other) that can be changed with heat treatment.Maleable steel does not have this property-some CASE hardening can be done,but its no substitue for spring steel.
Al Stokka - Cambrige, Iowa
>McMaster-Carr (www.mcmaster.com) has 1/8" x 1 1/2" x 25' coil of tempered scaleless 1074/1075 spring steel. Item 9074K278.
I am not suggesting the above is proper for your application, only that it is spring steel of the cross-section you requested.
It is both the formulation (primarily additional carbon) and heat-treating which gives a spring it's properties.
Al
>Gary Check out the small trailer springs. They might be the right size. I get a Northern Tools catalog and they have a lot of them.
Re: OT---Spring steel vs. regular steel *LINK*
Ron Bauman
>Just Google this. Anybody who can make springs for a Whippet ought to be able to help you.
http://http://www.eatonsprings.com/vehicles.htm
r payne
>The term spring steel refers to any one of various steel alloys that has been heat treated to give it a springyness. As a general rule any steel with 0.60 percent carbon can be treated to make a spring. Some alloying elements (especially in higher amounts) can make the steel brittle (chromium in excess of say 4 or 5 percent for example). A lot a modern leaf springs are 5160 or something similar. But there are other common alloys as well.
You can find steel suitable for spring easy and cheaply enough with a little looking. Once you get the steel it is a matter of heating, bending then heat treating. The heating can be local to where the bend needs to be and this can be accomplished with an OA torch. If you plan on bending it yourself I recommend you find someone willing to heat treat for you and for that you will need to know what alloy you're using (a definate problem if you use recycled steel even if it was a leaf spring previously).
Or you can find a spring shop to do the whole deal.
ron
>Thanks all,
That was what I suspected. The properties of spring steel are mostly due to the metallurgy.
I'll pass this info along to my brother-in-law. He's trying to get by on the cheap if he can. I think he needs 3 pieces about 30" long. They don't have to be formed for this particular application. They get a few holes drilled though. I imagine it will be harder to drill than normal steel.
He's just had a heckuva time finding what he's looking for. McMaster-Carr has 24" pieces, but that's not quite long enough. I think he's talked to nearly every steel supplier and metal-working shop in the area and hasn't found a source yet. The trailer makers might be a good idea, John. Someone cooperative might put him onto their spring supplier.
Thanks for all the input, guys,
Gary
r payne
>Drill it annealled (unhardened). It won't be much different than mild steel. If you heat treat it first it will be much harder to drill.
ron
