Re: Here ya go.... *LINK*
Grant Smith(remove 1 for email)
>Terry,
Sorry to hear about your issue with the dealership on a great truck. I have a 2003 1500, and have had no issues other than a steering column joint lube issue related to the TSB's.(taken care of by myself and a mechanic friend). Incidentally, my mechanic friend claims that this model of truck is GREAT mechanically.
Generally speaking, my experience with dealerships has NOT been good, so I share your disdain with the service department. I have mostly been victim of a "Holier than thou" attitude despite a demonstration of incompetence. My mechanic buddy also knows several dealership mechanics, and they are good guys, but every bushel of apples has a few rotten ones.
Anyway, I have attached a link to a Chevy bulletin board relating to all chevy's. I am not finding your particular problem, however. Not all the info includes the entire text of the TSB.
I suggest you ask the advice of a local (non-dealership) mechanic. Most of them also have access to the factory TSB's via automated shop manual software such as Snap-On's "Shop Key".
From what I know about brakes squeeking in general, there are a few causes:
-Excessive hard braking, causing them to get "glazed". This is a driving habit issue, and hard to prevent or correct unless you don't mind having the brake pads replaced often. Manifests itself as a mid frequency squeeeek as you stop. No offense, but I think this is the most common cause. You be the judge about if it may be your cause.
-Driving or living in a constantly dry area. Can cause the dust to build up and manifest itself with a squeek similar to the above.
-Design issue. Usually associated with aftermarket pads that proclaim long life, this issue can be corrected by avoiding the long life pads. Some brakes just squeek. I don't think GM uses these pads from the factory, though they may have changed to them recently.
-Morning squeek. Often noticed upon the first few brakings in the morning, especially if it has been damp and you parked outside overnight. Most noticable upon stopping as you back up the first time.
-Brake pads bad grinding. Not likely your issue if the truck is new. Grinding upon stopping and squeeling when driving at low speeds. This squeeling is the warning tabs on the pads telling you it is time for brake service.
All of that said, I believe there is a special greaselike compound that can be applied to specific places on your brakes to limit or decrease their tendency to squeek.
If you aren't getting satisfaction from your dealership, I suggest going up the chain until you get satisfaction as you have done. At worst, you can take your business to the next town over. You might consider simply calling the next towns dealership to see if you get a different answer. There is very little reason that your dealer should give you bad service, as they are compensated by GM for such warranty work.
Good luck!
Grant in Iowa<---not a mechanic, but I hang around a few and hear this complain a lot.
Chevy TSB index.
