Job in search of a tool - long
Mark Kauder, Phenix City, AL
>It is still some time before I put the exterior on my new shop extension, and the rest of the old shop.
I am still inclined toward Vinyl siding. When I created the storage on the end of the shop a couple of years ago, I used vinyl siding to pretty much match the Aluminum Sheet siding already on the rest of the building.
So, I have been reading up on the right way to do this. On the storage area, I used screws to fasten the siding to the exterior, but not knowing better then, I did not know that you need to fasten loosely so that the siding can expand and contract. Over that time, I saw no problems, but the vinyl sections were all less than 4'. Some of the new spans will be 20'-24'. So "loose fastening becomes an issue. I would prefer to use Stainless steel screws with built in washers. What I need is an electric screwdriver/screwdriver attachment that I can use that adjust to stop just before the screw contacts the siding. I am afraid that the built in clutches will not stop soon enough, even on the lowest setting. I kind of want a dry wall dimpler - in the opposite.
Ideas?
Mark
Re: Job in search of a tool - long
Gary Evans Tallassee, TN
>Hi Mark,
I don't know why an impact driver wouldn't work just fine. I just built a small deck out back. Probably went overboard, but I counter-sunk all the screw holes. I find that my little Ryobi impact driver lets me put the screw at the depth that I want. I think because the action is sort of intermittent as the hammer works, it lets you see the screw movement pretty well.
I've also used it to screw off drywall. It's not hard to control for dimpling.
I would guess that by the time you drove your 3rd or 4th screw, you'd have it down pat as to when to stop.
Gary
Re: Just educate your trigger finger
Ron Hildreth, Alta, Iowa
Dan Barber - Lebanon, TN
>Mark,
A drywall screw gun will probably work for what you need. They have an adjustable depth collar, it's typically used to control the depth the screw is driven into the drywall. It can be set to keep the screw above the surface on most models. I've never tried it on siding, but it seems to me that it would work.
I have used a pneumatic roofing nailer to hang siding before as well. The Senco I have has an adjustment to control the depth it drives the roofing nails and I set it to leave them proud of the surface about 3/32". It was a bit tricky to shoot it in the center of the nailing slot at first, but eventually I got very good at it. I wouldn't recommend it for everyone but it worked for me.
Re: Job in search of a tool - long OOPs!
>Mark, I would try a drywall dimpler but set it it leave the screw proud. My question would be whether the hole in it is big enough to accept the screw you want to use.
They make a nailer for joist hangers now. Two versions that I know of. One of them drives the nails and then makes a partial stroke to leave the tip of the nail sticking out so you can put it in the next hole. Another one has one of the impulse drivers attached to an angled magazine for a stick of nails. You put the tip in the hole and sort of vibrate the nail in. Don't know if either has a setting to leave the nail proud.
Wonder what the pro's do? If I see some of them working I'll stop and check.
Re: Job in search of a tool - Thanks
>Just wondering.
Barry, don't bother
Thanks all, I guess, I will just "Adjust my finger".
Mark
Randy Johnson Connersville, IN
>I've never installed a piece of siding in my life but I've been on a lot of jobs where someone else was doing it.
ALL I've ever seen used was nails. I don't know if it is because the pros regard them as better than screw or if they are simply cheaper and a little easier.
Re: Job in search of a tool - long *LINK*
Ian (in Sydney, Australia)
>You want one of these
they're designed to drive screws with neoprene washers into steel or timber purlins without splitting the washer.
But it might be very difficult to justify for a one off job
Metabo screw driver
Piece of sheet metal with a slot
Phil Joines Krum, TX
>I put vinyl siding on a 7 x 20 storage room 3 or 4 years ago. I used underlayment nails. Make a Z shaped shim from flashing with a slot for the nail. The Z shape lets you hang it on the edge of the siding so you can use both hands to nail.
Re: Piece of sheet metal with a slot
AJ in Ohio
>Just nail it!!!!
Lee Gordon
Lee Gordon
>I'm not sure I understand why you don't want to just use galvanized roofing nails rather than stainless steel screws. The nails are cheaper, easier to work with, and are what the siding is designed to to be used with.
John E. in SC
>I would agree - I'm no expert, but I would think galvanized nails would be MUCH cheaper, easier and faster to install, and would still outlast the "life span" of vinyl siding. I haven't personally installed vinyl, but like others mentioned, the only thing I've ever seen the pros use is nails.
Larry Clinton At Frankfort (Central)., Indiana
>We have installed vinyl siding on my shop, house, sons house and storage shed. We have always used roofing nails and have had no problems, either with the installation or life of the siding. The only place we have ever used screws was on a steel storage shed my youngest son built using a semi trailer. The galvanized roofing nails will outlast you, as well as the vinyl. You obviously don't require the holding power of screws as the siding is really supposed to be "hanging" on the nails. If a nail backs out a 1/16 or even an 1/8" it will have no effect on the siding job. Although I have a Senco roofing nailer, we have never used it for siding. Senco does make a siding nailer, never used one so don't know what they do to maintain the spacing and or help align the nail into the siding slots. If you are looking to have a automatic method of driving fasteners, I would look at the Senco. I definitely would not consider screws as they are expensive, slow to install and offer absolutely no advantage in appearance or life of the siding job. With someone cutting the siding, you can hang one to two squares an hour using a hammer and roofing nails. My 2 story, thirty by thirty foot shop took approximately 13 - 14 square, and with 4 people, sided it, and installed the fascia and soffit in one weekend.
