A55 Smoothing Plane
Question about sanding
Robert R Clough - Thorncraft
>I seem unable effectively to use a paom snader (and I've deliberately left that to show I can't spell either!) palm sander. To continue - I have a Porter Cable 1/4 sheet palm sander (I call them jitterbugs). This is the third one I've had over the years. For some reason I get large, terrible sanding marks after using it. Why??? I try to go slowly, very slowly, and steadily. I do not put pressure on the sander. Nevertheless I continue to get what I call skid marks and glacial gouges. It does not matter if I use 120 or 380 grit. Thus I have to spend time hand sanding.
Any suggestions?
Re: Question about sanding
You Sanding
Dustmaker Mike
>with the grain? Other then that I have no clue.
Keith Newton
>Always start these sanders before contacting the work, and pick them up before turning them off. You may also need to spend a little more time with each grit before going to the next, but don't leave the paper on after it is worn out. Garnet paper is only good for about 2 minutes before it is shot. Your time is worth more than the cost of keeping sharp paper on cutting faster.
I almost never use these sanders anymore, because the random orbit sanders cut so much faster. RO sanders should be in contact with the work when you start them.
Jim Dillon
>Robert,
Just guessing here. I have the PC 1/4 sheet size sander, but use my PC RO sander most and usually attached to a shop-vac. Are you getting those small, shiny spots on your sandpaper after a bit of sanding? (They have a name, but I'm having a senior moment right now.) If so, they might be causing your swirl marks in the wood. Try using stearated sandpaper to cut down on those marks in the wood. A second option would be to attach a shop-vac to your sander. My experience has been that this really helps minimize those glaze marks, prolongs the life of the sand paper, and, hopefully, the users life too. Lastly, you might try rubbing the sandpaper with one of those crepe rubber thingies designed to remove sanding swarf(?)(sp?). That last option works much better on belt sanders, at least for me. If all else fails, change your sandpaper more often.
Jim
Dave Bair, Eaton Rapids, MI
>My PC QuickSand finish sander will leave some pretty bad marks, but it is always due to a piece of loose grit trapped on the paper. Find and remove it and it'll work well again. Watch the dust trail left by the sander, if there's a streak in it, you know you have something that's probably leaving a gouge in your work.
