Cheapo Bandsaw
Cheapo Bandsaw
Cheapo Bandsaw
JerryB617
>I have a 9" Delta bandsaw that I purchased new about 3 years ago. I'm a fairly new self taught woodworker. My question is, can this bandsaw be supertuned or modified to do some resawing? I have used it sparingly with bad results, blade twisting, jumping off the tire, guides getting out of alignment. etc. I gave up on the darn thing and put it in the attic. I know a lot of woodworkers swear by their bandsaws but am I wasting time and money on this cheap model? I have an alternate e mail address if anyone would like to take time in advance to personally e mail me. Jerry.Barnett@appl.ge.com Thanks in advance, Jerry from Lou-a-vull
Re: Cheapo Bandsaw
Re: Cheapo Bandsaw
>Good Evening Jerry,
You may be over estimating the capability of your saw. The little Delta is a nice tool for small jobs. For resaw work I'd recommend a larger version, 14 inch or better with a dedicated resaw blade and a heavier motor. Keep the little guy for smaller jobs or sell it.
George
Re: Cheapo Bandsaw
Re: Cheapo Bandsaw
>IMO, I don't think a 9" can take a blade that is heavy enough for resaw work, but I could be wrong. I use a 1" blade on my Rikon 18". When I was using my 14", I was using at least a 7/8" and a lot of tension.
Re: Cheapo Bandsaw
Re: Cheapo Bandsaw
Tom MacGregor
>Your saw may be too small for much resawing but the right blade makes a big difference. I'm sold on Timberwolf blades from Suffolk Machinery. They have a chart for picking the best hook/tooth configuration, and if it turns out that you still can't get the results you're after it may still be handy to have an aggressive blade available for other stuff. Keep your feed rate slow and consider making a resaw fence that makes it easier to adjust for drift.
Re: Cheapo Bandsaw
Re: Cheapo Bandsaw
Falberg saw Co
>Everything you said was true; right up to the point where you said "consider making a resaw fence that makes it easier to adjust for drift"
Goofy fences are never a solution to blade drift; proper blade selection is. With a cheapo bandsaw like his you might have to manually reset the teeth on a 3TPI blade to do any real cutting. This can easily be done with a hammer and a punch on your vise in fifteen minutes. You'd be A-mazed at the difference!
