4" angle grinder
Joe Piotrowski - Chicago Burb's
>my shopping list is growing. anyone happy? disappointed with theres?
4" angle grinder
Re: 4" angle grinder
ScottS
>First advice: buy a 4.5" angle grinder rather than a 4" model. There's a larger selection of disks and accessories made for 4.5" grinders than their smaller brethern. Especially when I need to buy discs locally, I'm glad that I own the 4.5" tool!
I bought a cheap ($55-60) Makita 4.5" grinder and have been reasonably happy with it. It's easy to lock the grinder "on", which everyone claims is dangerous but I find to be useful during long grinding sessions. The handle position works well for me, which wasn't the case for the Bosch grinder that FHB (or was it FWW?) rated tops; I bought one and ended up returning it because it just felt.. wrong.
A single-speed grinder is great if all you need to do is remove material. If you want to use a grinder for, say, finishing metal I'd suggest buying a variable-speed model. It's possible to execute finish techniques using a single-speed grinder... but it takes more skill than I posses! With a variable-speed grinder, you can dial down the speed to make the tool more controllable. I currently have my eye on a Makita 4.5" variable-speed grinder.
Finally, make sure you have good eye and ear protection! My grinder is extremely loud. I don't think I'd attempt to use it on wood if I wasn't wearing some sort of full-face shield.
thanks.
>I looking to use it for some demolition work but it's future uses are unknown :)
Ron Hildreth, Alta, Iowa
>Joe,
I've had my Makita for years, have given hard use, even loaned it out to my BIL, who is known to destroy power tools, and have had no problems with it at all!
Ron in Iowa
4.5"
>I'm with Scott on this one, 4.5" accessories are easier to find and buy.
I have a DeWalt as well as a Milwaukee. Both have a metal gearbox, which in my opinion is a must for long life. Both are pretty loud, I can't remember which model has it but one (of the others, not mine) has a worm gear rather than a straight gear which is supposed to make it much quieter. The Milwaukee is quieter and smoother, and I prefer it over the DeWalt, but the DeWalt is a great tool tool. I've had the DeWalt long and had it has done alot of hard work. Like many metal related tools, I find that Milwaukee is better ones, liek drills and portable bandsaws and grinders. They may not be tops in the woodworking field, but they are close to the top in the metal working tool area.
From what I know and my experience with Makita, you can't go wrong with those either.
Happy Woodworking!
4.5 it is!
>it sounds like the big guys all are good. I'm going shopping today and I will see what I get.
so far 4.5", worm drive, variable speed.
Re: 4.5" angle grinder
Glenn Madsen near San Francisco
>My DeWalt has survived auto repair, demolition and renovation of a bathroom, including cutting ceramics, plumbing, installation scribing of prehung doors to fit misinstalled rough frames, and other horrors my sons haven't let me know about. If there's a better one out there, and there may be, I don't need that kind of quality. Yellow is more than good enough for me.
Only one answer - Metabo
Dan Barber
>Every heavy iron working job I have been on the millwrights and ironworkers all use Metabo 4.5" angle grinders - these things get the holy c*ap beat out of them and they somehow keep on working. It convinced me to buy two of them and they work great.
Here is possibly the neatest trick in the tool buying world - the older Ridgid brand 4.5" grinder available (possibly) at your local Home Depot for $89 is actually a Metabo. I think they may have changed suppliers recently, but if you can find one that looks like the image below except is orange and gray - that's the one to buy.
On the other hand it's available as a Metabo for $99 if you look around on the net. The model you want (with basic features) is Metabo 4 1/2" Grinder # W7-115
Switch
Tom Dunlap
>My Milwaukee is still spining away on me. MANY times I've gotten it so hot that it smelled nasty and I just ran the thing to cool it off, then let it set for a while to cool down.
I like the paddle switch under my fingers to turn it on and off. I would never have another slider switch after having my old Makita go dancing around trying to cut my leg.
Lung protection too
Phil Joines Krum, TX
>Steel dust is worse than most woods.
Amen!
ScottS
>Amen to that! When I'm grinding for more than about 60-seconds, I always put on a dust mask or (more often) some sort of respirator. I've learned the hard way that steel is more of a problem for me that just about any wood...
