Power Washer
Power Washer
Power Washer
Joe Piotrowski - Chicago Burb's
>I need a better power washer. I have one of those cheap 80 dollar all plastic POS.
it's for basically washing a deck, pvc fence, car, sidewalk etc. i don;t need a commercial one. between the brands that Menards,Home depot and Lowes carry, what is a good one?
I recall Mark G has few but if anyone else has some recommendations I would be happy to hear them.
Re: Power Washer
Re: Power Washer
Ken Oakley-Sunny St. Cloud, Fla.
>I have a 2300 PSI one from HD with a Honda motor. When I have a choice I buy anything with a Honda motor. Have had mine 6 or 7 years with moderate homeowners use plus friends and neighbors sometimes. Zero problems and still starts on first or second pull
Re: Power Washer
I've got the one with the Honda
>I've got the one with the Honda GX200 engine (200cc 6.5HP). THe GX series is Honda's red/white one with the white metal tank and the red metal cover. It has a cast iron sleeve and overhead cam. Honda also has their GC series which has the black plastic tanks, etc.
The one I have also has the shiny blue Italian pump... I can't recall the name at the moment, but it was the most highly rated pump at the time.
They still sell them, or something close with the same components. I think on with a GX160 (5.5HP 160cc) engine would be fine.
Happy Woodworking!
Re: Power Washer
Here ya go..... *LINK*
SanMan
>....FWIW...I have this one....
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200241274_200241274
....but there lots to choose from.
Its all the washer I really need.
Cheerio,
SM
Northern Tool
Re: Power Washer
Re: Power Washer
Rob Stokes in North Vancouver
>I picked up a used Honda 11HP 3000 psi unit with 100' feet of hose for $400 (Cdn). It's overkill for what I need, but the price was sure right. I had a 4HP Briggs unit (Craftsman) before that and it never failed to make me angry whenever I used it. It was a total POS - never again.
Rob
Re: Power Washer
How much pressure?? Mini-hijack, but applicable.
Joe Pack
>How much pressure is "enough?" I don't want to blast holes in steel, just wash my siding, clean the concrete patio, etc. What specs would be sufficient to do that, with a little extra power just in case?
Re: Power Washer
Re: How much pressure?? Mini-hijack, but applicabl
>2000 psi would be a minimum, but you'll want at least 3 GPM to go with it (not 2.8, you want an actual 3). Keep in mind that this is assuming you'll be doing a sidewalk once a year and maybe a deck or two. 2000 psi won't remove stains, but it'll remove dirt/algae from concrete/house walls and is strong enough to dig out wood from a deck when you don't want to.
3000 psi is a lot more usable as it's got the extra power if you need it. If you don't need it you can run the nozzle farther away from the surface and clean a larger area a lot quicker. Mine's 3000 psi @ 4gpm (uses an 11HP Honda) and is a pleasure to use. I'm working the engine too - there's washers out there that must be magic as they advertise 3000 psi @ 4gpm using an 8 or 9HP engine. I'm not sure how they do that...
Oh - get a wand that has interchangeable tips. don't get a wand that has an "adjustable" tip. They work OK when new, but soon turn into a disappointment.
Rob
Re: Power Washer
Re: Power Washer
Dave Morris
>I have a Work Pro 2700 PSI with a Honda 6.0 HP OHC engine, 4 separate nozzles for different spray patterns, and 75' of hose. It was about 500 bucks, IIRC, and about the best thing available locally before stepping up to much more expensive and powerful washers. It will write your name in concrete if you get the tip too close, and does a great job on most household chores from a nice distance.
Having used one of those small portable plastic-bodied power washers to blast all the old paint and wallpaper off a couple thousand board feet of old growth redwood interior/exterior siding from two old houses we tore down, I can attest to your pain with using such a washer. They are hard to get anything off before you get too close and drill a hole in the wood. A larger power washer is one of those rare tools you'll find new uses for all the time It'll even blast all the black stuff off your abalone trimmings so you can make some GREAT chowder... trust me on this one. ;-)
Get a washer with separate replaceable nozzles, and more hose than you think you need--- nothing sucks worse than to be at the top of a ladder and come up two feet short of reaching that one particular spot that sticks out like a sore thumb but is a real PITA to get to.
Dave--- who thinks there's nuttin' better than 2700 PSI for blasting hornet nests from a safe distance
Re: Power Washer
Big Lots
Dustmaker Mike
>has a 2400 PSI Karcher with Honda motor here in OH you may want to check one local to you. I have the same one but I paid a little more for it at Costco. I cleaned my old Log home top to bottom and a few others also. It starts first or second pull and runs Great
Re: Power Washer
Thanks Rob.
Joe Pack
