OT - Network Connections Help
Pete Stahl from S. Jersey
>I bought a new PCI Wired Network Adapter card. When I go to Network Connections I see 2 items one says connected, the new one I bought the other says Network Cable Unplugged. I double click on the Opened one and it show the Sent/Received activity and also the Connection time. I still can't connect to the internet. How to I connect to this connection? I'm assuming I must need to change something somewhere. The other thing I tried is there is a connection built into the PC (Pentium 4 with XP Pro)and it's called Intel(R) Pro/100 VE Network Connection. When I plug into this one it says the cable is not connected. Any help is much appreciated.
thanks, Pete
Re: OT - Network Connections Help
John McGaw
>Well, first things first. You say that you have two network connections available on this computer and that when you connect to either one the diagnostic message is "cable unplugged". Are you using the same cable each time? What is on the other end of the cable? Have you tried a different cable? Depending on what you are trying to connect to the cable required may be different -- basically there are two types: a "flipped" type where receive -> transmit at each end and an "unflipped" type and the sort you need is dependent on what it is connected between. Also, is the connected device (modem? router? switch? hub? another PC?) known to be working properly?
>John,
The new Network card says Connected and I'm using a Network card on the PC (PC w/ Win 2000 Pro) I typing this message on. I switch both ports on the router and both cable and both work fine. If I try to open Firefox to go to the Internet it doesn't work. It did work when I was using the wireless card. The wireless card was uninstalled, new driver for New Network card was installed and computer booted. New Network card says connected in Network Connections but can't get to Internet.
John McGaw
>Is the router set up to provide IP addresses to connected devices? Has an IP address been assigned to the new network card, either manually or by DHCP from the router? Can you access one computer from the other -- share files etc? Does the computer with the new card have a firewall running and is the firewall letting communications through?
I know that I'm burying you in questions but I'm still not confident that I understand what your overall setup is and what has been tested and what hasn't.
>John,
The more questions the better. Below I answered the questions.
thanks again.
ans: Don't know, how can I check this?
ans: Don't know this either, wireless card worked when it was set to Obtain a IP address automatically.
ans: Yes I can access the other PC's shared files and print which has to be done through the Win 2000 PC.
ans: Turned off the firewall.
>Don't know if this is exactly what did it but I went into the Internet settings and added a connection under the "Connection Tab" where it says "Dial-up and Virtual Network Settings" and also click the button at "Never dial a connection". Rebooted again and it works now, go figure. Thanks again for all the replies.
