>I've always had a problem in my basement shop of dusty conditions at the furnace/laundry room, so I got busy this weekend and built a wall between my shop and the furnace/laundry room. I've installed normal single doors (hinged one side) before, but this time I opted for a 60" wide, four panel bi-fold door, which has two of the panels on the right and two on the left when opened. What I'm unsure of is the rough opening I'll need to create before hanging this door. Nominal height is 80". Am I going to need more heighth and width than, say the 80 x 61 1/2", allowing for the 1x trim?
This is the first time I've ever installed a door like this, and was hoping to avoid any surprises! Thanks for any help you guys might have!
>Usually doors like this have a little installation sheet attached that clearly shows sections and dimensions of the rough opening. If not, figure it out empirically: lay the door on the floor in the exact arrangement that it will have when hung, arrange the top track and guides/rollers the way they will be and allow however much room at the bottom for guides (if any) and/or floor clearance you might need. Then measure the outside dimensions of the whole shooting match, add an inch on each side for jambs (3/4" plus shim space), and there's your rough opening. Depending on the track arrangement and how you handle it, you will either attach the track directly to the header and flank it on either side with partial jamb strips, or you will install a single head jamb and screw the track to it. In this case, you would need an extra inch of headroom at the top for the head jamb and shims.
Hope this helps. When in doubt, make the R.O. bigger; you can always pack it in with spacers if necessary, but you can't expand it without ripping out your framing.
>I'm a little confused by what you refer to as the Rough opening. Having been a builder and trim carpenter in a previous existence, we called Rough Opening the opening in the framing and Finished Opening the opening in the trim or jamb.
The finished opening I preferred for bifold door was 60" by 81" on a hard floor and 81 1/2" to 3/4" on carpet.
The rough opening in the framing was 62' by 82 1/4 to 83". Often, We framed the opening with a header made of two 2 x 10's sandwiched between a two by four and a one by four.
The reason the opening was taller for carpet was I preferred to put a little filler block about 1 1/2 by 3" under the foot of the pivot hardware, rather than "bury" it in the carpet. It seemed much sturdier to me and it was easier to get the doors in the opening if they were a little taller rather than a little shorter.
You may also wish to install the doors just behind center in the opening. This way, it is easy to run door stop across the top and down both sides so as to hide the track and conceal the gap at the jambs. If you center the track on the head jamb, be sure there is enough room left for the stop.
Also, the knobs should go on the doors about two inches in from the hinges on the two center panels. Some people center them on the inner panels, but I find the doors harder to operate if the knobs are not nearer the hinges.
Ellis is correct, If you make the opening in the framing too big, you can pad it down easer than open it up. If you are unsure and have not bought the trim jamb and doors, let the sheetrock extend into the opening a bit all the way around and cut it out later. Drywall is easy to cut, but tough to patch.
Guess I should have explained a little better. This is in my basement, and I've already built the wall on the right side of the proposed doorway, and I just have to determine the side to side distance of the rough opening, and start the wall building on the left side. 81" above the concrete floor of the proposed door is an existing 8"x 8" wood beam that supports the center of the floor above, so will have to use it for my header to have enough clearance below the door at the floor. Not much room to work with top to bottom, but enough I hope. Might have to trim off the bottom of the door, as a worse case senario. As for trim, since it's in the basement, won't be a critical item, just need to install the jams so doors will somewhat seal out the dust from the shop. Barry- the door knobs are already drilled in the center of the panels, so not terribly happy about that, after what you said about easier if mounted close to the hinges of the center panel. Been a long time since doing any rough carpentry work, so was a little fuzzy on dimensions. Thanks for jogging the memory. I printed out your responses to keep me on track!
BTW- Company that manufactured the door is trying to save the trees--no instructions!!
>Having hung quite a few bi-fold doors for Habitat for Humanity homes, my best advice is make the opening "square and plumb" from the get go for best appearance and low frustration for you.
>Ron, The advice about keeping things plumb, level and square is excellent. These door really look and work better if the head jamb is level and the leg jambs are plumb.
I think 81" is a little low. Be careful about cutting the doors off. For one thing, if you must cut them, cut them off square. They don't fold well and look like crap if you angle them on either end. Also, the pivots bear on and are supported by the frame strips in the ends of the doors. If you cut off more than about a quarter or half inch you won't have enough left to support the pivot. The strip must be thick enough to support the weight and to keep the pivot from wobbling as the doors pivot. I know this because I cut about an inch off some once and basically had a strip of veneer left in the end of the door. OOOPs!
So either cut a little off each end or cut a lot off one end and replace the strips. I actually used to cut them down and then saw the strip out of the scrap and glue it back in the end.
