solid maple vanity top!
Steve Silca
>I have access to several 3' x 6' solid maple 1 1/2" thick table tops from my high school. They are getting rid of them. At the school, I plan to plane them down to expose new maple (we have a 24" surface planer).
I would like to use part of one of them to make a new top for my vanity. After sanding and staining the fresh maple, what would you put on as a good finish that will be impervious to water? How many coats?
Thanks!
Re: solid maple vanity top!
>Behr makes a clear water based one-part epoxy for garage floors that I think will work well. I used it on a carved wood sign (two coats) a couple years ago. The sign has been continuously exposed to the elements and shows no deterioration. I plan to use it on a bathroom vanity top of ash.
Clint
Available at Home Depot?
Steve Silca
Yes
A question about that epoxy, Clint.
Gary Evans Tallassee, TN
>How is that clear floor coating for dispersing bubbles? I have some display tables that I would like to epoxy, but much of what I've seen with epoxy coatings has had an excess of bubbles, at least in my view.
I know you have to be careful about stirring in bubbles with epoxy and wonder whether this stuff has it over 2-part epoxies in the retaining bubbles category.
Thanks,
Gary
Re: A question about that epoxy, Clint.
>This stuff is nothing like the two-part epoxies; it's more like a heavy bodied water borne poly. I used a poly/nylon brush to lay it on in a fairly heavy coat without working it too much, as it sets up pretty fast. Didn't get any bubbles. Two coats is plenty. I'm gonna try a test to see how it rubs out.
Clint
