A55 Smoothing Plane
Countertops and cabinets...
>I will be building shop cabinets in the near future. I was figuring on getting some reasonably inexpensive shop grade hardwood plywood for the bodies of the cabinets. I was kicking around ideas with my wife for the countertops. Her suggestion was heavily finished hardwood plywood. I had been thinking formica. The more I thought, the better I liked her idea.
Is this a reasonable idea?
Which plywood to use? I was planning on face framing the cabinet bases and putting a 1 7/8" or 2" edge banding on the front of the countertop to cover the plywood seam. The lumber place has all of the usual plywoods.
Re: Countertops and cabinets...
Gene Gauss
>I'd think twice about hardwood plywood. The surface layer looks good, but in my experience, is very thin and probably wouldn't stand up well to wear. Gene Gauss
David Hay @ Denver
>I probably wouldn't use formica. It's too slippery. When I get around to building some cabinets for my shop, I intend to build the top with a plywood or 2x4 frame, covered with a layer of 3/4" plywood and a layer of 1/4" hardboard. When the hardboard gets too beat up, I can easily replace it with a new piece.
David
Joe in a Cleveland suburb
>JL I do what David does. I use Masonite as the top and replace it as needed. Seems to work fine. Too bad they don't make a lighter colored version of it though.
Joe
>I used generic 3/4 T&G strip oak flooring on mine. Tough and looks good finished or unfinished.
Clint
Ron Hildreth, Alta, Iowa
>Good Morning, JL
I'm just in the process of building a new work bench and upper cabinets for my shop, and I hate to admit it, but instead of building my own (I'm too expensive!), I bought three 30"w x 24"h x 12"d Melimine cabinets at Menards for about $50 each, installed a kick panel base under them to raise them up a little. I then raised the counter up by using 2x6s under them stood on edge that I will be inserting drawers between. Brings the final work surface up to a comfortable 34", which is what I like. I used 3/4" MDF for the work surface covered with 1/4" Masonite. I really like the added storage space all this created, as I was needing a place to store my portable power tools to get them out of the dust.
Ron in Iowa
Re: The majority votes for sacrificial hardboard..
>I can live with that. I can make a frame out of hardwood with a bottom layer or two of plywood. I wouldn't even have to use pretty stuff for that plywood. I can use shop grade hardwood plywood for the cabinets (whatever's inexpensive).
Does hardboard come in any color other than brown??
Mark McC
>If the counter tops are not necessarily going to be used as a working benchtop or heavy work area, I wouldn't shy away from the hardwood plywood idea. I used maple 3/4 veener core edge trimmed in maple for a back bench counter top over some floor cabinets I made. It has held up great for 10+ years. I give it and my main bench a coat of tung oil couple times a year and it looks fine.
Again it's not for assembly, mostly seems to be used for collecting junk, scraps, clutter!!!
Mark
Re: The primary use will be holding up..
>boards ends. I am going to build a 17' long set of cabinets. The center section will be 3 1/2" shorter and 26" wide and I will put my compound miter saw there. I will use the countertop to support the longer boards while I cut them. My work bench is will be nearby.
Re: Countertops and cabinets... another option
Dave Morris
>Two walls of my shop/garage have cabinets. One is a row of cabinets I built out of plywood with oak face frames.
The other is from a bunch of wall and floor cabinets a relative donated when they remodeled their kitchen. I raised the floor units with an extra toe-kick, left a couple spaces between some cabinets to house my air compressor and router table when not in use, placed all the floor units 4 inches away from the wall to run DC piping behind them, tied/topped all the floor units together with three layers of MDF trimmed to fit flush to the wall and supported by a cleat, and then skinned the worktop surface in hardboard. Rock solid, takes a beating without causing me any tears about trashing my work, and as said in above posts, the hardboard is easy to replace.
Of the two walls, the kitchen cabinet wall was a lot less hassle to create while working in a *very* crowded work space. Old cabinets from house remodeling can be found pretty easily. Some contractors are happy to have you take them off their hands so they don't have to dispose of the cabinets themselves. Just something to consider.
Dave--- who mounted his SCMS on the worktop, placed three of the wall cabinets so they "framed" it from above and the sides, and routed one 4" DC pipe behind the cabinets to catch the dust as it was made... best workshop improvement so far
>That's sort of what I'm doing. My brother-in-law donated his upper cabinets to the cause. I was going to take his lower one, but there was no room in the truck. I'm cutting a hole in microwave/stove exhaust cabinet and ducting my DC piping down through that. I'm just building the base cabinets.
