Electrical and Cable
Ron
>Can you put a cable outlet and a electrical plug in in the same box rather then having them separate on the wall thanks RON
Ron
Re: Electrical and Cable
C.W.Stivison
>It is never a good idea to put high voltage wire and signal wire in the same box.
My 2 cents
CW
Why not?
Tom Dunlap
>CW,
Can you explain why you feel that way? Does it have something to do with the high power interfering with cable/phone/comm wiring? If so, that would seem odd since I've seen high and low strung pretty close together from the pole to the house and surely through the walls.
There must be another reason...
Tom
Re: Why not?
>I've heard a nasty 60 cycle hum on phone lines strung with electrical. I don't know how it would affect cable though.
Jim Swank
>Check for a coverplate that fits what you want first. I see no great technical problem doing that, but if you can't find the cover, it will always be a thorn in your side even if all works well.
check code
Joe Piotrowski - Chicago Burb's
>use shielded LV cable if you must.
Re: Why not?
Bill Howatt
>60 Hz is an audio signal and even though it is outside the phones passband which I think is in the region of 400 to 4000Hz it is close enough to have an effect. Cable frequencies are far, far away, 54MHz and up, so 60Hz is unlikely to have an effect.
I don't know what the code says but I have never seen a 120V outlet receptacle and a cable outlet combined faceplate. On general good wiring practices which says keep signal and power separate, I wouldn't do it.
Bill
I wouldn't
John in New Mexico
>Too much chance of getting zapped when fiddling with the cable. Put in a remodel box for the cable right next to the outlet if you've got space problems.
John
Re: I wouldn't
Wess
>Definite no go. You also can't run low voltage and line voltage in the same conduit or thread it through the same holes in a stud.
Pretty sure you can't
>Low voltage wiring (phones, network, cable, alarm, HVAC) MUST be completely seperate for high voltage. Around here at least. There are rules (code? law?) that even specify how far apart different wiring must be from each other. So putting them in the same box certainly isn't allowed. Around here at least.
Happy Woodworking!
code here say's no Re: Electrical and Cable
del schisler
>code say's no
Not allowed by NEC
Tim Greif - West of Chicago
>You can't put any communications (or audio) conductors in any raceway, box or enclosure containing power conductors. The only exception is if the box or raceway has an approved barrier separating the two. Panduit makes raceway and boxes that comply with this.
Bottom line - keep it separate.
