Mini lathe table
bhenr99
>Does anyone know or have a plan for a portable table or cabinet with a couple of drawers for a mini lathe? Thanks for any help.
Bob
Mini lathe table
bhenr99
Bob
Re: Mini lathe table
Don Henthorn
>Here's one. I have another one but right now I can't find it. When I do I will post it for you.
MountainMan
>Yeah! Thats a cool bench - the instructions are in Shop notes vol 12, issue 67... If you don't have it I may be able to send you a PDF - it is pretty big - about 8000k.. email me at the above address..
Regards
The MountainMan
Jim Dillon
>bhenr99,
I also made the Shopnotes mini-lathe bench and it is very nice IMHO. Nearly smashed my toe when the VERY heavy top dropped off some jury-rigged sawhorses that I was using while putting a hardwood edge on. The carcass of the bench is made from MDF so it is really heavy and eliminates vibration. It is easy to build. It is also somewhat portable as the unit is on wheels that can be raised (to lock the bench in place) or lowered (to move it). The two small drawers hold the turning tools in custom-cut holders with no bottoms in the drawers to avoid turning debris build-up. If you can't get your hands on the Shopnotes, I can make a copy and send it to you although it might take a week or so. Here is my version. I used scrap hickory for the door/drawer fronts and top edging. Highly recommended.
Jim
