OT Kerosene Monitor heater
Kieran
>I have been herating my shop with a Monitor heater for the last six yeasr or so without any problems. Several days ago I came in to the shop to find the lights on the control panel blinking and noticed a smell of kerosene in the shop. No apparent fuel line leak. Tank is outside. I checked the ooutdoor pipe and noted it was covered with snow. Normally this is not a problem because the hot exhaust melts any higher drifts that may come off the roof. Heater is up and running with burmer status light reading normal. I am still however, getting a kerosene smell in the shop. CO dectector (just put in a brand new one) is not alarming.
I have to confesss that I have never had it serviced and come to think of it, have never changed the filter on the outside tank. I normally only get out to the shop on weekends and weekdays keep the heater set at around 50 degrees.
Any suggestions or help would be greatly appreciated. Thanks in advance.
Kieran
Re: OT Kerosene Monitor heater
Re: http://www.alsheating.com/MonitorHeater.htm
Al Stokka - Cambrige, Iowa
Kirk D.
>Bad news. Same thing happened to me the other day. Searched on the internet to find service options and found Al's Heating in Maine. Depending on the model you have there is a good chance your heater might be headed for the landfill. Thats what I did with mine. It hurts when you outlay that kind of cash for crap - but you are not alone. Check Al's website before you are soaked for more. Before you dump it check your model number as some of the old ones appear to be good enough to fix.
Good luck and it feels better when you can't see it anymore. Mine died on the coldest night of the winter to weeks ago. $1400.00 down the drain.
Dale Stansbery
>I used to heat with fuel oil. My experience was that you have to replace the filter, preferably yearly, as well as check for water. I suppose that the amount of dirt and water introduced into your holding tank is a function of the supplier, but mine always got gunky in a year or so. With your filter off, open the shutoff valve and flush the line behind the filter, as sludge can also build up in the line. I'm not familiar with your heater, but if it has a wick, it probably needs replaced. If not, the burner may need a thorough cleaning. I had a big old Sears pot style burner, and the air baffles in the burner burned out, and it became ineffecient and smelled and sooted up the chimney.
Kieran
>Thanks to all. Odor seems to have dissipated. Burner is working on full status. Maybe I have escaped a bullet this time!
