ARGH! How much is too much? (long)
Dave Morris
>Frustration, that is. Case in point, the old Jet bandsaw I'm restoring. True, I had a pretty good idea it was a Sad B*st*rd when I decided to give it a go. It didn't run, I had no idea how many things were wrong with it, but I thought I could give it a shot.
Now I start assembling it, and find the lower cast aluminum wheel is bent. I couldn't tell before, as everything was froze up. Pull out my TS-Aligner, and set it up to measure the wheel wobble from a steady reference point on the bandsaw table. Total variation over the course of one wheel rotation is .042". Then I test it by slight "finger" pressure (cupla-5 pounds, guessing) and I can push the rim .003" towards the cast base of the saw, and pull it .002". Don't think that in itself would hurt anything under operation, but the bend in the wheel would seem like the wheel is toast for any future use.
Then I checked the wheel shaft to see if that was contributing to the problem. Good news is the shaft shows no variation at all, or at least hardly enough to make the needle on the dial indicator move-- maybe .00025" at the farthest end of the shaft (quarter of a thou... heck, that could just be dust on the shaft or scaring from wheel removal).
Proceed with some more assembly to see what else is wrong, and find the threaded rod for adjusting the upper wheel tension has some worn threads in one spot, and doesn't wanna play anymore past that point. Okay, I've heard lots of good stuff about the hand crank offered by Iturra, and was figuring on getting that down the road a bit. It looks like I'll bite the bullet sooner than I thought and order one now, plus a new tension spring just to be on the safe side.
I received the manual for this old saw from Jet (JBS-14MW, model 708516), and true, some parts are no longer available. However, the wheels shown in the old manual for my old saw look like flat discs with 6 round holes spaced equally around the disc, but my saw has the "6 curled spoke" wheels shown in the manual for the newer saws offered by Jet (JWBS-14CS/OS/MW, models 708113A, 708115K, and 708116K). My saw has a shaft diameter of .77", or what I'm guessing is a 3/4" opening on the wheel. Anybody know if the lower wheel for the new model Jet bandsaws will fit my older saw?
Anyway, progress report-- I've already replaced all the bearings, rebuilt and reinforced the saw's base cabinet, designed and built a new sliding motor mount that will allow using all the sizes of the motor step pulley for some extra speed options, added a riser kit (had to remove the locating pins for that one), had a new extended hexagon guide bar fabricated to match the riser block, had a new three-speed shaft fabricated to replace the old trashed shaft, re-bopped the electricals by relocating a new power switch to the frame and adding an outlet for a light, new power cord, added link belts, new tires, cleaned and painted all parts, yadda, yadda, yadda... Yeah, I know, I'm already in too deep, but there is a certain satisfaction I get from learning new things and taking on a challenge like this. Call it a flaw in my character. ;-)
Thanks for any answers, advice, or SWAGs on ordering a new lower wheel for this saw.
Dave--- hoping it'll be worth all the trouble when the job is done
Re: ARGH! How much is too much? (long)
Phil Joines Krum, TX
>Don't know about the interchange but are there any machine shops around who could straiten it?
Dave Morris
>Thanks for the response, Phil. I hadn't thought of that option. I can't believe Jet would let something like that slip out the door, so since some sort of impact bent it, I suppose the wheel could be bent back. Wouldn't the wheel have to be bent back "beyond" straight to come back to normal after the pressure is released? I haven't a clue how much sideways stress these cast aluminum wheels can take.
The new wheel lists for about 37 bucks from Jet, according to the parts list in the new manual. It's probably less than it would cost for a machine shop to spend some time futzing with the old wheel. Hence my question about installing a brand spanky new wheel.
Thanks again for the response. With all the Jet owners out there, I was thought maybe "somebody" might have replaced a lower wheel on an old Jet bandsaw before.
Dave--- hoping to get through on Jet's hotline before work this morning
