Question about padauk
Larry Marker in Alabama
>I have a couple small pieces of padauk that I bought a number of years ago. They have been stored in a closet for several years. I want to use them in a small project and I got them out and they are a beautiful dark reddish brown. I wiped one with a damp paper towel to get an idea what it would look like finished and the paper towel turned quite red.
Is this normal? Does the color bleed out like that with just a swipe of a damp cloth, or has this wood been died? If this is normal, do I need to do anything special in the way of finishing it? (I've been planning on using oil based poly.)
Larry
Larry
Re: Question about padauk
Mark Kauder, Phenix City, AL
>Larry,
Yes, Paduak bleeds it's color more easily then just about any wood I know. I use a lot of it. The only things to consider, is if you are using it with other wood. 1)The sanding dust is pretty invasive. Since I an turning with it, but you could do it with flat woodworking certainly - if you have paduak next to other wood a) seal the light colored wood as you sand, or use a scraper in those areas. 2)I try to have a dark boundry layer (black veneer in my case) between the Paduak and the lighter wood. That way when you finish, wipe on your poly up to that line, and then up to that line from the light wood side. Once you have a coat or two on, and they are relativey dry, you can finish cross that line.
Mark
>Also the Padauk will change color over the years to more of burgundy brown so be sure any wood you put next to it is contrasty enough to not blend in as the years go buy. Lighter woods work well with Padauk but as Mark said the sanding dust will carry over and stain the light woods. I coat the wood with sanding sealer before I ever touch it with sandpaper and sometimes even inbetween grits.
Thanks - would this work?
>Thanks Mark and John.
The use I had in mind would have a thin (about 1/8 inch) strip sandwiched between two pieces of padauk. I want a very light wood and was thinking of hard maple.
Not sanding the joint is going to be difficult because this will be done at the joint where two pieces come together at a 22.5 deg miter.
Maybe I should make the piece solid padauk, sand it, put a couple coats of sealer on it, and then cut a shallow kerf and inset the maple. The maple would be a little proud of the padauk and I could sneak up on it with sandpaper and then finish it with a scraper.
Would shelac make a good seal coat for the padauk?
Larry
