Re: Quick Electrical Question
Fred Davis fredd
>to flatly say that a 15 amp outlet is allowed on a twenty amp circuit does not address the code that requires a dedicated twenty amp circuit such as a garbage disposal, dishwasher , list is as long as you want to reflect on.
In addition if they havn't downgraded the NEC requirements , you can't combine light runs and outlets on the same circuit except in the case of a switched outlet you normally would plug a lamp into.
In addition, if you run a 20 amp dedicated circuit that has a switched load on it, such as a disposal, then the switch has to be rated 20 amp as well.
Lastly , if you will think about it, using 15 amp outlets on a twenty amp circuit as a cost saving measure is foolish when you consider that the 20 amp breaker protection for the 12 awg wire could let thru enough current in a overload situation to melt down the 15 amp outlet without kicking out the breaker.
In all cases of electrical supplies, buy American, the stuff made in Mexico will fail sooner then later and may burn your house down.
FredD
Retired General Contractor
