>In an attempt tp be a good soul, I'm helping someone repair some drywall. More than some actually. Before Ram Jack was brought in lots of cracks developed.
Anyway ..... I can't get a nice smooth finish on the compound. If I were to put it in familiar terms, I'd say I get micro bubbles. I'm no pro with a 10" knife by any means, but I can't get the bubbles to disappear no matter what I try.
A little internet research suggested if the mud was overmixed I'd get air bubbles. As if I over whipped it. This is a distinct possibility.
No bubbles are tape related. All in the mud. Some are actual small bubbles. Some defects appear more as small surface voids left behind as the knife glides over the mud.
I figured someone here would have some first hand experience with this stuff, and there's got to be a simple explanation.
Having done a bit of mudding in my time (not as a profession...;) I have found that small voids on the initial application are common. However, after sanding the joint with a sanding board, a thinned application is used for a "skim" coat on all joints to fill in any of the voids left after sanding and to "blend" or "feather" in the edges to the surrounding surfaces between to sheets of rock, which is why they taper on the edges. (usually using a wider blade as well.) Sometimes, it takes a couple of skim coats to get a satisfactory result. Lastly, you can then do some spot coats on any stubborn areas. Always sand between coats and be very careful not to "fuzz" the paper on the sheet rock at the edges of the mud... it will show badly when it comes time to paint. If you are getting fuzz, your sanding too far from the edge of the mud, too hard (pressure), too rough of a grit... or a combination of all three.
If you are getting good sized bubbles along the tape line, then you are trapping air behind the tape when you apply it. You should first apply a coat of mud, then the tape and follow up with your blade to set the tape into the mud and against the wall. Don't press and drag too hard or you risk starving the joint and there will not be enough mud to set the tape. Some tapers will use an additional application of mud when setting the tape into the first mudding. The pros will use a "Banjo" filled with mud and a roll of tape on a reel and go to town.
If you are filling cracks in existing walls, as opposed to taping and mudding new sheet rock, then you want to make sure the surface will accept the mud and be very careful about feathering in the patches or it will stand out like a sore thumb. If the old walls are textured and you are patching, vs. replacing entire surfaces, you will want to re-texture the areas to match the existing wall. You can get kits at HD or else where to allow you to spray some texture (thinned mud) on the patches.
Lastly, don't try to mix your own mud... it is better in the long run to buy the premixed stuff by the box.
>Even if you buy the pre-mixed stuff in either the buckets or the boxes, you should thin it with water--this will help reduce the bubbles. It's easier to put on a couple more thin coats of mud than it is to sand off one bad, thick one. Personally, I like to use mud that is pretty sloppy wet. It flows under the knife much more easily, so it's easier on my hands and wrists, and after the knife passes over it, it will have a nice glossy sheen that helps you spot defects (bumps, divots, gouges, chucks, etc). Also, it's okay to leave a ridge off the edge of your knife. A "ridge" is easier to sand (or even scrape off with your knife when dry) than a "valley" or a "plateau".
If you do scuff the drywall paper when you sand, don't worry, just give it a light sanding again after the primer dries (this is a good thing to do anyway).
While I have never tried it, some add a drop or two of liquid detergent to the mud to minimize bubbles. As others have pointed out, don't try to repair the drywall in one step. Far better to use thin skim coats multiple times. The sanding between coats will be a lot less and the drying time will be less as well.
Jim (still a real hack when it comes to drywall, but improving)
>You have gotten good advice. Use premixed mud. Start with it slightly thinned with water for the first coat and don't over mix it. Try to skim on the first coat low and thin. Much easier to fill later than to sand and fill. Start with a narrow knife and work up to a wider one. I bed tape with a 4", coat with a 6" and skim out with a 10", then sand and touch up or skim again.
The joke is that the first primer coat of paint is really just to reveal what you missed with the drywall mud. You will have to touch up again.
Also, I like the fiberglass "gauze" tape better than paper for flat seams. If you are making repairs and don't have the tapered edges to "hide" the seam in, you need to be especially careful to press in or cut away anything that bulges above the surface. Easy to fill a hole, very difficult to cover a bump or bulge. The fiberglass tape is sticky and self adheres. You just press it in place and skim it with mud. The mud will flow through and fill the voids behind. Much easier than applying a base coat of mud and then pressing it out from under the paper tape.
A thinned coat of mud will skim out your bubbles.
Do your final sanding with fairly coarse sand paper. 80 or 120 grit, but no finer. You want the surface to have the same texture as the surrounding area, If you sand it really slick, it will shine through. Sanding screen on a sanding pole works great for this.
If you get good, you may be able to avoid a lot of sanding by wiping down the joints with wet burlap or a really coarse wet sponge. It will do a good job of knocking of little ridges and feathering the edges. The smearing action of the wet sponge will fill tiny voids also.
You mentioned Ram Jack. I take it the house has been leveled and that cracked it in a number of places. I had a number of houses moved and they had (surprisingly few) cracks. The trick is to make the patch very thin and very wide. This is where the fiberglass tape pays off. With no mud under it, it is thinner than paper tape.
An 1/16" thick by ten inch wide patch shows a lot less than one a 1/8" thick by six inches.
The houses I moved had a few cracks in them and then more showed up over the next month of two and the house adjusted to its new foundation. I wonder if your Ram Jack experience will be the same. I bet you will find cracks that appear later and you will wonder how you missed them.
Ram Jack was in at least 5 years ago, so things should have settled out by now. Or stopped settling. Long story as to why no repairs as of yet.
This is all repair work. To make matters worse, most all of the cracks are at corners of windows and doors, which means not only do I not have tapered edges, but I'm working on cracks between casing and the ceiling. Someone with a lot of experience would be fine, but it has proven to complicate my learning curve.
Believe it or not, I added a bit of detergent. I think I over whipped it. I also think some of what I've seen is probably normal, and I've simply had little reference point to know that. I also know that I wanted better results than I was getting. Unfortunately, the more you mess with it the worse it gets!
>I absolutely hate sanding mud, so to keep it to a minimum, I do the first coat only thick enough to fill the seam or otherwise cover the tape (if its not the compressed edge). Smooth out any bumps in it now without regard to how it looks- as its much easier than sanding them down later. I like to use hot mud so I can come back in an hour and recoat with one or two thin coats for the finished surface. And here we finally get to (maybe) answer the question- Bubbles and lumps can be worked out easily with a fair amount of pressure. Once you get the hang of it, should only take two passes, one applying mud, one smoothing.
If you are just doing small spots, use the fiberglass tape that someone else recommended and sand with a sanding sponge. The fiberglass tape is stronger than the paper, plus it is thinner, as mentioned. The wet sanding will cut out the mess that sanding dust makes, plus it will provide the filling action, also previously mentioned.
Gary----Lots of sheetrock patching in my former life as a remodeler
