Re: Please help choosing new planer...
arw01
>I bought the DW735 in June 2004. I've run likely over a 1000bf through it by now, most of that in small passes. There was a large run of air dried bull pine that became a deck on a trailer where I was hogging off quite a bit per pass on high speed.
My initial set of knives is still in the planer. There are a couple of knicks on one side, but I try to use the bed evenly each time I use it. Those ridges take literly seconds to sand down with 220, or a couple passes with a hand scrapper.
The machine is noisy, but I wear some earmuffs for that. The fan assisted dust collection definetly helps as well. My only issue is I need to clean my rollers, and some pitch built up on the dust shroud which can lead to some chips laying on the bed.
Someday I will win a set of knives on ebay for CHEAP and then I will rotate my original set of knives.
As a another side note, a friend of mine has one as well which survived WAY for wood than mine sees. It took a nail to the cutter head one day. The head and knives were destroyed, but they were replaceable for less than 1/2 the cost of the planer.
Alan
