Gluing panels and keeping them flat
bill tindal, E.TN
>The question of how to make the joints flat in a panel glue up comes up from time to time and most recently in a post below.
1.A furniture factory, or anyone owning a large planer, would skip dress (that is hit and miss planing or face jointing to get a flat but not finished surface), glue the skip dressed pieces and run the assembly through a planer. This approach is guaranteed to yield a flat panel, but most of us don't have planers of sufficient width for this to always be a solution.
2.Next best is to glue up what will fit through your planer and then glue these finish planed sub assemblies into the finished panel size. I do this approach regularly.
3.If you don't own a planer then you are stuck getting every joint as flat as possible.
So, in cases 2 & 3 what is the best way to get a joint flat with no edges sticking up, or down? My goal is to get the joint edges flat to better than 1/64" so that a few swipes with the hand plane or belt sander leaves the joint smooth. The following works for me.
I don't use cauls or biscuits. They are unnecessary and somewhere between a distraction and hinderence to the process. I don't think cauls will ensure a joint as flat as I can routinely achieve with out them.
I do use stiff bar clamps. I prefer the clamps made by the Universal Clamp company but any BAR clamp will do. Stiff clamps don't flex which results in bowed panels. It is unnecessary to alternate clamps top and bottom if the bars are stiff ( there is an exception to this guideline if the stock is very thin such that it will flex). I use what the furniture factories use-yellow glue.
It is helpful, but not essential, to begin with flat lumber. Flat lumber such as what will result from face jointing lumber, is one less problem to worry about when making the joint. However, we sold thousands of feet of finished planed lumber to cabinet shops that then successfully glued cabinet panels from them. So, it certainly is possible to make panels from less than perfectly flat stock.
The more joints you try to glue at one time the more problem you will have keeping all of them as flat as possible. For critical work I glue one joint at a time, but most times I will do two or three if necessary to get the finished size.
The following is what I do if I want the joint to be as flat as possible. I have the boards laying on the clamps as shown in the picture with ample glue on one edge. I then rub the joint together to transfer glue to the second surface (this just saves time over smearing glue on both surfaces). I start at one end of the joint carefully aligning it and then lightly snugging the clamp. How much pressure to apply here is what will take the most practice. It must be enough to hold the joint but not so much as it tightens up the joint at the next clamp. Then move to the next clamp, 10-12" away, and by lifting the low board (or pushing the high board) align the edge as perfect as you can and snug this clamp. I feel the joint as it should be covered by some glue squeeze out if sufficient glue was applied. Repeat this process until the last clamp is snugged. Then go back an tighten all the clamps a bit more. Look to see if the panel is flat on the clamps which are flat on the bench. If some edge sticks up, bang it flat to the clamp with a hammer. It will easily skid against the metal clamp face. Finally, securely tighten all the clamps .
Note: Yellow glue is terrifically shock resistant in the partially cured state. Banging on a recalcitrant joint will rarely move it. However, partially cured glue will easily yield to shear. Therefore, pressure will coax a joint into alignment. In an extreme case I fixed a jack between a clamped panel and the upper floor joists and pushed a badly bowed board into alignment. In other cases I have pulled down a bowed board end by C-clamping the bowed board in this assembly at the edge of the bench.
The picture shows gluing the last board in this panel assembly. This panel is too thin and frail to run through the power planer so I wanted the joints to be glued flat so hand planing would be quick and easy. I have done the joints one at a time, for this reason. You can see the squeeze out on the last joint. You can't see any high edges because edges are aligned perfect.
