Since you asked, here's the answer......
>I already emailed you, but for the sake of other's here who might want to learn also, here's what's up.
I'm afraid I know this particular BSOD all too well.
Bad news is... it means (most likely) that Windows is corrupt.
Good news is that your data is likely fine.
There are two things you can do.
If you are more interested in preserving the data that's probably still on it, you can (or have someone do this for you)
- remove the existing hard drive
- purchase and install a new hard drive
- install the new hard drive as your primary master
- install Windows using the Recovery/OperatingSystem CD's that should ahve come with your PC. This will bring your PC back to the way it was when it came from the factory.
- install the old hard drive back in the computer, but this time as a secondary or slave drive
- run your computer using Windows on the new hard drive (C), and access the old drive (likely D) to go and copy the old data from that drive to your new drive.
If this is the route you go, you might need help from me or someone else help your identify and find your data on the old hard drive, because depending on the software your data may be in different and obscure places.
The other choice, if you are more interested in fixing your current hard drive at the risk of making it worse, and you can do this:
- Boot your PC using a bootable WindowsXP CD, and instead of installing Windows, go into Windows reapir mode.
- In the Windows Repair mode, which is basically just an old fassion DOS screen, you can enter the following DOS commands.
rem Instructions:
rem Boot Computer [F8] to safe mode menu
rem Go into Recovery Console
rem enter follwing commands
mkdir C:\WINDOWS\fixtemp
copy C:\WINDOWS\SYSTEM32\CONFIG\system C:\WINDOWS\fixtemp\system.bak
copy C:\WINDOWS\SYSTEM32\CONFIG\software C:\WINDOWS\fixtemp\software.bak
copy C:\WINDOWS\SYSTEM32\CONFIG\sam C:\WINDOWS\fixtemp\sam.bak
copy C:\WINDOWS\SYSTEM32\CONFIG\security C:\WINDOWS\fixtemp\security.bak
copy C:\WINDOWS\SYSTEM32\CONFIG\default C:\WINDOWS\fixtemp\default.bak
delete C:\WINDOWS\SYSTEM32\CONFIG\system
delete C:\WINDOWS\SYSTEM32\CONFIG\software
delete C:\WINDOWS\SYSTEM32\CONFIG\sam
delete C:\WINDOWS\SYSTEM32\CONFIG\security
delete C:\WINDOWS\SYSTEM32\CONFIG\default
copy C:\WINDOWS\repair\system.bak C:\WINDOWS\SYSTEM32\CONFIG\system
copy C:\WINDOWS\repair\software.bak C:\WINDOWS\SYSTEM32\CONFIG\software
copy C:\WINDOWS\repair\sam.bak C:\WINDOWS\SYSTEM32\CONFIG\sam
copy C:\WINDOWS\repair\security.bak C:\WINDOWS\SYSTEM32\CONFIG\security
copy C:\WINDOWS\repair\default.bak C:\WINDOWS\SYSTEM32\CONFIG\default
Note; this is not for the faint of heart, and it's not 100% the wya Microsoft prescribes the rememdy, but it works. I've had to do it too many times.
Happy Woodworking!
