electronics question
Rick Snyder
>Hello, anybody out there know why a TV would all of a sudden lose the sound on one channel, while the rest of channels are ok. If it's a bulb/tube were would you be able to buy something like that. (Columbus,Ohio area)
Thanks, Rick
Re: electronics question
Dan Donaldson
>Doubtful that you would be able to buy parts to fix it. TV's these days are all solid state, so no tubes to replace. If they die, you would need schematics and some troubleshooting knowledge to have any chance of fixing it, and even then, it is possible that it is in a chip which you probably would not be able to get..
Bill Howatt
>Are you speaking of channels like TV station A on channel 5 and TV station B on channel 6 or channels as in left stereo channel or right stero channel?
If it is the TV station channels it doesn't make sense except perhaps your tuner does not have the exact tuning voltage for that channel and the sound part of the signal is not being properly tuned. If you have a "manual tuning" adjustment on the TV you might try fiddling with that with the TV tuned to that channel. Has it been like this for a while now? Could be the station's fault.
If it is a sound channel then sounds like something from the decoder onward to the speaker has gone bad. Like Dan said, there is nothing you can fix yourself and you need to take it to a shop.
Bill
dave in washington
>Rick, I had the same thing happen to me recently after a power outage. It took me a week or so of intermittent fooling around with a remote control with about a hundred buttons on it. It only affected PBS and I could n't figure out why. Finally solved it by switching the audio to "stereo". Evidently, PBS uses mono audio transmission and it was transmitting on either the right or left channel only. Worth a try....
Same here.....
>Stereo vs mono should be a fairly easy thing to handle, but I find that sometimes it can lead to perplexing problems and a simple flick of a switch puts everything back the way it was.
High tech remotes sure have a tendancy to have the improper buttons hit causing sound outages.
I'll admit that on more than one occasion, while wathcing a DVD movie, the remote get's hit while reaching for popcorn and then the sound goes out. After struggling with the remote to restore it for a minute or two, we usually resort to powering everything down and turning it back on and it goes back to default (normal) mode and we can hear the movie again. Same is true for the Closed Captioning that seems to be much easier to accidentally turn on that it is to actively turn off.
Happy Woodworking!
Lee Gordon
Lee Gordon
>This may be a bit obvious, but have you tried viewing that same station on a different stereo TV? It could be that there's nothing wrong with your TV and the source of the problem is the TV station.
DB
>Check your TV setup settings to see if the sound is being processed through something called SAP. If it is change it to something else. That station might not be broadcasting a SAP compatible signal.
Found that out when trying to record witn my DVD recorder. Worked fine on all of the other channels but the one channel had a good picture but lousy sound.
Tates in Chesterfield, VA
>If you are using a cable box, try unplugging the box and wait about 30 seconds and then plug it in. It should go through a boot sequence resetting it. I had this happen last week and that is what the cable people talked me thourgh.
