ot mobile home addition
Jerry Gibbs
>We want to add a small addition to our mobile home in Florida. I may be having trouble attracting a builder. I know nothing about working with metal as a structural material, especially tying the addition in. the addition needs to be at least skinned with aluminum to satisfy the park. Any starting places if I have to do this myself? Jerry Gibbs
Re: ot mobile home addition
Ernie Miller
>build it more as a deck type room that is bolted to the mobil home and can be unbolted if it ever has to be moved. because of roof problems make it so you have to step down a step or two into the room that way you will have more head room as you put a sloap on the roof. the entire weight of the room will have to be self supporting on piers of some sort. steel skin is easy to install that should be no problem. Use the right Flashing where the roof's meet that will be a critical point and the same for the side walls. Sollid floor support is probably the most important part you don't want it shaking away from the trailer when the kids get to jumping around.
Ted Wong
>I wouldn't think that adding on to a mobile home would be much different than building an addition on a conventional home. Whether your unit is built from structural insulated panels (SIP's) or conventional stud frame the procedure of cutting into the existing house and adding on will be similar. Something will have to take the roof load down to the ground where you make the hole in the existing house which means a header will need to be installed etc. Without knowing what the covenants in your housing development are I'd have to say installing aluminum siding either vertically or horizontally would probably satisfy their rules and then it becomes a matter of either learning how to do it yourself or calling a siding contractor.
Larry Clinton At Frankfort (Central)., Indiana
>I have installed new furnaces and central air in a few Mobile homes. One issue that is somewhat of a problem is providing power (120 volt for outlets and lighting and possibly 220 Volt for Air conditioning). Be sure you can obtain the proper breaker for your entrance or run a new line from the Pole drop if possible. If you can run a new line from the drop, you can install a load center (check local codes) and thus power the addition. One other area of concern, be sure to match the material used on the addition to the MH. Do not use steel siding if the MH has aluminum - doing so will cause a lot of corrosion problems. As others have suggested, a step down allows for easy roof slope - although if you run the peak of the addition perpendicular to the mobile home roof - you should be able to maintain the same height albeit with a little sealing problem where the MH meets the addition. I would be tempted to build a freestanding structure with 4 finished walls and a passageway from the MH to the structure using a flexible seal to the MH. This would allow simple construction, guarantee no leveling issues and would have little effect on the resale value of the MH in the event the addition is removed. This is provided you mean the addition to be at one of the existing doors of the MH and not an addition like a "tip out". I am sure you could remove part of a wall and extend the side of a MH with an addition - but it might be more costly than trading for a larger trailer with the existing tip out.
