Strip or plane?
Strip or plane?
Strip or plane?
Terry Alexander
>I have a lot of 1" thick ash that came from a very old house. This ash was used as wall coverting! Yep.....wall covering. It looks like it was pickled and then a light coat of either varnish or poly. On the "work side" there is a thin layer of construction adhesive.
I really don't want to strip all of these boards. I probably have +/- 150 boards, 4" to 6" wide and a full 8' long.
I have the Delta 22-580 planer and am not real keen on running these boards through it. My thinking may be wrong. An alternative would be to purchase a cheap planer to get the poly and construction adhesive off and then use my 22-580 to finish the job.
Am I being over-protective of my 22-580?
Will the planing of the poly harm my 22-580?
Will the planing of the adhesive side harm my 22-580?
As always....I thank you in advance for your valued opinions.
Terry Alexander
Re: Strip or plane?
Re: Strip or plane?
bill tindal, E.TN
>Looks like you have about 500 bd ft of lumber of some grade. Are there nail holes every 16" or not? How clear is the lumber. Bottom line, what is the value of what you have in hand if it was planed? I don't see it as very much unless it is mostly clear, ie. no nail holes or other defects in most of it.
This lumber will dull your knives so figure in the price of resharpening after you plane it. Other than that I don't see how the lumber could hurt the planer.
Re: Strip or plane?
Re: Strip or plane?
Jesse in New Mexico
>If you have a bandsaw, shave 1/16th off the dirty side, leaving clean but rough lumber for the planer. It will dull your bandsaw blade, but they are a lot cheaper than a planer knife. If you have an old dull one around, so much the better.
Re: Strip or plane?
Sand Them
>If there is a cabinet or mill shop in your area that has an industrial wide belt sander you could ask them, for a fee, to run your material through their sander. One pass would probably do it.
Tom
Re: Strip or plane?
Plane them - use old knives if you have any
Stephen Kirk in Quakertown, PA
>I've planed off a good bit of finish. It sure is faster than stripping, and the clean up is easier. If you've got an old set of knives, swap them in, no sense using good sharp ones for a task like this (Hey, maybe that's what I should keep some of my old sets for!). As stated above, look really close for nails or any other hard debris (dirt, rocks, staples, tacks, etc). Maybe do a quick sanding of each board with a heavy grit just to expose anything you'll want to get out. Probably a good idea to clean the planer up after your done too.
I'm all for re-purposing old lumber. A few nail holes won't weaken a piece of furniture much, and can even add a bit of history to it. And you know your doing good for the environment (even if only a bit). It's amazing what you can find underneath layers of paint on some old board.
Re: Strip or plane?
Ooops, shoulda put this under the main thread
Re: Strip or plane?
Use a cabinet scraper
Charles Sharp
Re: Strip or plane?
Re: Strip or plane?
jmohnike
>Head to Harbor Freight or some similar store, buy an elcheapo power hand plane for around $35-40, you can also knock down the edges with it. You will spend more than that on a good set of replacement blades for your Delta and on sandpaper which has been my experience.
Joe
Re: Strip or plane?
Re: Strip or plane?
>Good Afternoon Terry,
I would run a metal detector over the boards before committing them to my planer to insure there wasn't something really BIG imbeded in the wood. Then, I would have at it with knives which needed sharpening at the time. Switch to newly sharpened knives for the final passes. In my opinion, this is the best method over stripping. I've done a lot of both. Consider the time spent in stripping against the cost of sharpening (or even buying )knives. My last house was over 100 years oild and had layers of enamel paint layed over the original chestnut. I took the boards and the planer outside and let the wind blow all the dust away. It worked very well.
George
Re: Strip or plane?
Re: Strip or plane?
David Yoho
>Terry,
I wouldn't hesitate to use my 22-580 for such a purpose. I also wouldn't hesitate using the blades that are in it and just replace or flip them afterward. A new set only costs $40 and you can clean the rollers and such during blade replacement too.
David
Re: Strip or plane?
I used an old Ryobi lunch box planer to remove
Don Henthorn
>the finish from about 60 sq. ft. of old pine flooring. Dulled the blades by they were easily sharpened.
