Burr Management aka Sharpening *LINK*
Peter Galbert
>I've posted some observations on sharpening what we can't see
Chair Notes
Peter Galbert
Chair Notes
Re: Burr Management aka Sharpening
bill tindal, E.TN
>Your hypothesis on edge dulling is not supported by pictures taken of edges dulling. I have never see a picture showing a bent over edge on a plane iron. However, I have seen at least a deformed, but not bent over, edge on some chisels ( a particular steel) used for dovetailing and other pounding operations. Typically, the toughness of the tool steels used for woodworking tools will lead them to fail by chipping if a fine edge is subjected to a bending force. On a plane iron the original edge is simply gone, presumably from abrasion, a seen in the typical attached picture.
The PIC
bill tindal, E.TN
Re: The PIC
Peter Galbert
>You could very well be correct. What I am refering to is based more on the experience of feeling a burr, or bent teeth on a tool and taking it to my finest stones and "touching it up". This most often returns the edge to a useful state. Of course, through extended use, the edge will be dull and need more intensive honing.
