ADVERTISE HERE - FREE TRIAL
Jointer Technique Question
JD Anderson
>I did a search, but did not see a post pertaining to my fairly basic question.
I have an 8" Delta Jointer (bought in 1995) and a Dewalt 12" planer (from 1996).
I am trying to build some tabletops, and I was wondering about jointer techniques (because my glue ups are not coming out great).
I am running the boards through the jointer flat, then tipping on edge to put a 90 angle from the flat side on one of the thin sides. I then run it through the planer (jointed flat side down) to make the two flat sides parallel. I then rip it on the table saw with the jointed edge to the saw fence (Delta Unisaw).
I am getting glue joints with the edges of the boards at different heights, which requires a great deal of sanding. I am using a Dewalt biscuit joiner to get good alignment on the assembly.
I believe my technique is correct, but I am assuming my problems are starting at the jointer when I get one side of the board perfectly flat.
Could someone who knows what they are doing give me a few pointers on jointer technique (do you maintain pressure on the board over the cutterhead, just the front of the board and drag the remainder behind, etc... I have some nice equipment, but I'm doing something wrong.
I have already confirmed that my jointer is at 90 degrees to the bed.
Thanks for your help!
JD Anderson
Re: Jointer Technique Question
del schisler
>a jointer will get the board flat But not the same thickness on each end of the board I guess you know that
Sue McLam in Orange, VT
>JD,
I assume that you plane the boards to all the same thickness. I suspect that the problem is with the biscuit slots. They are not precision slots i.e. there is some slop in them. I would recommend that you don't use biscuits at all, just edge glue. Then when you're clamping the boards up you can use care to align them flush with one another.
Sue
Jim Dillon
>JD,
You've got some nice equipment and your basic technique sounds good. I've had good luck with the following approach to using the jointer. Once the leading edge of your board is safely past the cutterhead by a foot or so, shift your left hand to the leading edge and lightly keep the first foot or so of the board in contact with the outfield bed surface. Walk your leading hand back toward the blade as more of the board crosses the cutterhead, but never press directly over the cutterhead. If too much pressure is applied to the board, it can actually bend, leading to uneven board thickness. At the same time your right hand acts to feed the board into the cutterhead. Others may have useful approaches as well. All this assumes your jointer beds are set up OK. If your jointed board is flat on one side, the planer should then do its job just fine. Good luck.
Jim
Mac in Indy
>Sounds like you have the basics right. as has been said it is assumed that you are face jou=intiing, edge jointing, planing and then ripping the boards as a group or set. that way all boards are the same thickness end to end. I also do not use biscuits for edge gluing anymore, there is sufficient slop in the location and fit of the biscuits that they alone will not assure good allignment and they do nothing to strengthen a edge to edge glueline.
When jointing I always transfer my hands to the outfeed side of the jointer as soon as is practicle since that is your reference surface and the board must stay flat on that surface to give you a continuous flat plane on your board.
Some misallignment errors at glueup can be corrected with the use of clamping cauls across the boards, above and below, clamped on either end. this is an external allignment tool that takes the place of the biscuits and does a better job. I usually place a set in a few inches from each end and then one iin the middle of an average size table top. It is a dance getting these tightened at the same time you tighten the edge clamps. I tend to tighten the allignment clamps a bit first and then the edge clamps. Be sure to put wax paper under the cauls so you don't glue them to your table top! You can also run packiing tape along the cauls to eliminate sticking to the glue. At least a couple of companies make edge clamps that also do the alligning job. The ones I use are from Lee Valley. You buy the hardware and provide the machined wood pieces. Check them out, they work real well.
That's my $0.02 worth.
Mac
>After you joint one side of the board, is it actually flat? You should not assume that just because you ran it over the jointer, it is really flat. Look at them. Lay them on the table of you Unisaw and see if they mate nicely with it's surface. (asumming it is flat). If you joint a flexible board you can put enough pressure on it to spring it down onto the cutter head and joint it, but it will spring back and be curved again. The pressure should be on the points that are touching the table. That shoull be the out feed table and whatever part of the board that touches the infeed table. Some boards are so warped or winded its a good idea to "knock them down" with a hand plane or a set of router rails first.
And The biscuits do have some slop in them. I have a plate jointer and really like it, but use it less and less. The consensus seems to be that the modern glues are so good they are un-necessary on long grain joints. I do put a few in when working alone to speed things up. Maybe one at the ends and one in the middle. Then I putt he clapms on lightly, tap the surface into alignment and then tighten the clamps. I don't have an assmebly table, so my TS has to do double duty, but I am careful to be sure that the panel is flat when I finish tightening the clamps.
suggestions
bill tindal, E.TN
>1. skip the biscuits as they are of no use
2. If you have stiff bar clamps forget the cauls. They will just be a distraction and provide no benefit.
3. Fundamental principle- It is easy to get one level joint in a glue-up and progressively harder to get more than one at a time. So......
4. What you are doing is fine , but just initially "skip dress" on the jointer and planer. Skip dressing is taking a pass to get things fairly flat but not a finished surface. Then glue up as many skip dressed boards as will fit through the planer width, maybe 12" or what ever. Plane these to finished thickness and glue them one joint at a time to get total width of top. When making the joint have the two pieces laying on the clamps with ample glue on one edge. Then bring the edges together at one end and very lightly tighten the end clamp. Move to next clamp (about10-12" away) and raise or lower the board to align the joint and lightly tighten this clamp. Work your way to other end and then go back and tighten all the clamps. The result should align to within 1/64 or better. That is as good as I can typically do.
This advice is a result of gluing thousands of panels. Furniture factories skip dress, glue and then dress the panel on planes big enough to do the whole panel, up to 36" or more.
If you don't own stiff bar clamps go buy some. I am especially fond of the "Universal" aluminum bar clamps sold by Woodcraft and others or available direct from manufacturer in lots of 10.
wilbur
>I'm having a bit of a problem visualizing your situation exactly (need more sleep), but I've always found that if I think there s a problem with my jointer, to double check the alignment of both the infeed and outfeed tables with the jointer blades. I've been surprised on more than one occasion.
Dance of the Wax-Papered Cauls
Dave Morris
>Mac In Indy Posted:
" It is a dance getting these tightened at the same time you tighten the edge clamps. I tend to tighten the alignment clamps a bit first and then the edge clamps. Be sure to put wax paper under the cauls so you don't glue them to your table top!"
Another thing to watch for is just letting the wax paper lay across all the loose boards as you glue them together. Wet glue can "drag" the paper a bit as you tighten the boards, and pressure from the cauls can try to keep the wax paper in place. I found this out the hard way when gluing up a panel one time--- I'd laid several pieces of wax paper across the panel to completely cover it, and then laid the cauls over the wax paper. The paper was laid parallel to the boards, but perpendicular to the cauls. The result? A bit of wax paper was pushed between two of the boards as I was clamping the panel together. Argh!... ruined the joint. Had to rip the panel along the joint and reglue before cutting the panel to size.
Lesson learned. Now I tape the wax paper to the cauls, one piece lengthwise along each caul and fixed in place to the caul beyond the edge of the panel. You don't have to cover the whole panel with wax paper. End of problem.
Not related to the original jointer technique question, but since it does relate to keeping the panel flat during glue-up... Well, I thought it might fit in.
Dave--- who wishes somebody had given him this tip before it happened to him
Stephen Kirk in Quakertown, PA
>I'd second the recommendation that you check the boards for flat after they come off the jointer and then insure that you plane all the boards to a uniform thickness. Then to the table saw to rip a parallel long edge, then glue them up. Bill is absolutely correct in not trying to glue up too many panels at once, and keeping them a hair thicker and planing down to finished thickness. It may seem odd to only glue up 2 boards at a time, wait for the glue to dry, then glue 2 more, but the couple hours you spend waiting (and working on something else) are probably better then a lot of time spent sanding (which can lead to dished and unlevel surfaces).
If you've got a lot of material to remove from board, hand planing can take it down fast.
ebd
ebd
>I agree with Mac. The edge clamps that have the alignment strips built in are worth their weight in gold because they make it so quick & easy to get an excellent glue up. The ones I have are from Woodworkers Warehouse (they still in business? - store here closed). I almost think I saw them in a Harbor Freight too. I think Woodcraft carries them too. If you watch for them on sale they can be pretty inexpensive.
clear packing tape on the cauls
RobinCorell in Atascadero CA
>I like to use packing tape on my cauls or any other clamping form that might get glue on it. It is one less thing moving around durning the glue up plus it is reusabe.
I too do not like biscuts because of the slop in my dewalt joiner. There are times when it is necessary to use them so I have learned a few things that limit their inacuracy to a more acceptqable tollerance. I try to always use the fence on the top of the board to register the location of the cut rather than the bottom of the joiner on the work surface. I do this in case the board has any warp or twist that is lifting it off the work surface or more likely, a bit of saw dust that will cause the board to lift up and make that slot a bit diferent in its location. Perhaps the most important is the brand of biscuts. Porter-Cable are the worst and can vary in thickness by up to .030". The best brands are either frued or lamello with only a couple thousands in variation.
And when it comes down to it a table top only needs apear flat. if it is off a bit acording to a straight edge it is really no big deal as long as it looks flat.
Robin Corell
Ted Wong
>Sounds like you have the process down correctly. Without standing next to you it's hard to give pointers on technique.
But some things I tell my students:
1) flatten and joint one edge
2) plane the opposing face on all boards. Sending all the boards through the planer at the
same setting before readjusting the planer for the next pass.
3) rip the opposing edge of the previously jointed edge on the tablesaw.
4) arrange the boards in the fashion they will be glued up in. With a pencil draw a big
triangle that spans the width of all the boards.
5) at each joint mark one board at the edge as (I) and the other board as (O) at the edge.
6) return to the jointer and edge joint each board. If the edge is marked with an (I) then
have the face of that board facing in towards the fence. If it is marked with an (O) that
face should be facing out away from the fence. This will help cancel out any
discrepency in the fence if it is off of true 90 degrees.
7) When gluing. Start with two boards for the first glue-up. Have the clamps laid out
(usually about 8"-10" apart staggered every other one between bottom and top. As you
tighten the clamps you can work the joint flush by tweaking one board or the other to
bring it into line as you tighten clamp.
8) Add consecutive boards as the previous joint sets up. Do not try to glue all boards at
the sametime or more than one joint a time.
9) Have a good glue-up session.
This sounds similar
sawdustdan
>To a couple glue ups I've had. What I figured out was my biscuit joiner was not registering to the board properly/consistantly. The resulting slots were cut at a slight angle.
Course in those cases I did not dry fit first which would have caught the problem
Dan
JD Anderson
>Wow, it's been a long time since I've been to Wood Central. I forgot how amazingly helpful everyone is...
Thanks for all of your responses. I've tried your input and I'm having better luck. I have another table to make tomorrow and I'll implement all of the input!
If you'd like to see some photos of what I'm working on, I've posted a few here:
www.nemoscoffeeshop.blogspot.com
Thanks,
JD Anderson
Also, here is my photography site (in caseyou are bored):
www.pbase.com/jdanderson
Agree With Sue
Question
Pat Evans
>Where one board is high, is the same board low on the opposite face of the top? Just trying to see if the problem is alignment or thickness.
